i am using a few NCC PIR sensors and they all working fine. But when I’m trying to change the settings of my new PIR sensor (PD02Z) I have some issues.
When I want to disable the motion detection led indication the condig value will change to “disable” but the sensor still blinks when it detects movement. I never had issues with my other PIR sensors.
I also noticed that my new sensor is named as “…PIR V2” and that the config options differ from the other (also PD02Z
) sensors. For example, the motion detection sensitivity has now the values: lowest, lower, high and normal instead of an integer between 8 and 255.
Any idea how to fix it?
My log is showing the following
2019-03-04 18:46:26.490 Info, Node019, Value::Set - COMMAND_CLASS_CONFIGURATION - Motion detection LED indication - 10 - 1 - Disable
2019-03-04 18:46:26.490 Info, Node019, Configuration::Set - Parameter=10, Value=0 Size=1
2019-03-04 18:46:26.490 Detail,
2019-03-04 18:46:26.490 Detail, Node019, Queuing (WakeUp) ConfigurationCmd_Set (Node=19): 0x01, 0x0c, 0x00, 0x13, 0x13, 0x05, 0x70, 0x04, 0x0a, 0x01, 0x00, 0x25, 0x6f, 0xc3
2019-03-04 18:46:26.490 Detail, Node019, Queuing (WakeUp) ConfigurationCmd_Get (Node=19): 0x01, 0x0a, 0x00, 0x13, 0x13, 0x03, 0x70, 0x05, 0x0a, 0x25, 0x70, 0xdc
2019-03-04 18:46:28.098 Detail, Node019, Received: 0x01, 0x16, 0x00, 0x49, 0x84, 0x13, 0x10, 0x04, 0x07, 0x01, 0x5e, 0x86, 0x72, 0x5a, 0x73, 0x80, 0x31, 0x71, 0x30, 0x70, 0x85, 0x59, 0x84, 0x7e
2019-03-04 18:46:28.098 Info, Node019, UPDATE_STATE_NODE_INFO_RECEIVED from node 19
2019-03-04 18:46:28.099 Detail, Node019, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Dynamic live=1
2019-03-04 18:46:28.099 Detail, Node019, QueryStage_Dynamic
2019-03-04 18:46:28.099 Detail, Node019, Queuing (WakeUp) BasicCmd_Get (Node=19): 0x01, 0x09, 0x00, 0x13, 0x13, 0x02, 0x20, 0x02, 0x25, 0x71, 0x82
2019-03-04 18:46:28.099 Detail, Node019, Queuing (WakeUp) SensorBinaryCmd_Get (Node=19): 0x01, 0x09, 0x00, 0x13, 0x13, 0x02, 0x30, 0x02, 0x25, 0x72, 0x91
2019-03-04 18:46:28.100 Detail,
2019-03-04 18:46:28.100 Detail, Node019, Queuing (WakeUp) SensorMultilevelCmd_Get (Node=19): 0x01, 0x0a, 0x00, 0x13, 0x13, 0x03, 0x31, 0x04, 0x01, 0x25, 0x73, 0x94
2019-03-04 18:46:28.100 Detail, Node019, Queuing (WakeUp) SensorMultilevelCmd_Get (Node=19): 0x01, 0x0a, 0x00, 0x13, 0x13, 0x03, 0x31, 0x04, 0x03, 0x25, 0x74, 0x91
2019-03-04 18:46:28.101 Detail, Node019, Queuing (WakeUp) AlarmCmd_Get (Node=19): 0x01, 0x0c, 0x00, 0x13, 0x13, 0x05, 0x71, 0x04, 0x00, 0x07, 0x01, 0x25, 0x75, 0xd5
2019-03-04 18:46:28.101 Detail, Node019, Queuing (WakeUp) BatteryCmd_Get (Node=19): 0x01, 0x09, 0x00, 0x13, 0x13, 0x02, 0x80, 0x02, 0x25, 0x76, 0x25
2019-03-04 18:46:28.101 Info,
2019-03-04 18:46:28.101 Detail, Node019, Queuing (WakeUp) Query Stage Complete (Dynamic)
2019-03-04 18:46:28.101 Info, Node019, Node 19 has been marked as awake
2019-03-04 18:46:28.101 Detail, Node019, Queuing (WakeUp) ConfigurationCmd_Set (Node=19): 0x01, 0x0c, 0x00, 0x13, 0x13, 0x05, 0x70, 0x04, 0x0a, 0x01, 0x01, 0x25, 0x6d, 0xc0
2019-03-04 18:46:28.102 Detail, Node019, Queuing (WakeUp) ConfigurationCmd_Set (Node=19): 0x01, 0x0c, 0x00, 0x13, 0x13, 0x05, 0x70, 0x04, 0x0a, 0x01, 0x00, 0x25, 0x6f, 0xc3
2019-03-04 18:46:28.102 Detail, Node019, Queuing (WakeUp) ConfigurationCmd_Get (Node=19): 0x01, 0x0a, 0x00, 0x13, 0x13, 0x03, 0x70, 0x05, 0x0a, 0x25, 0x70, 0xdc
2019-03-04 18:46:28.102 Detail, Node019, Queuing (WakeUp) BasicCmd_Get (Node=19): 0x01, 0x09, 0x00, 0x13, 0x13, 0x02, 0x20, 0x02, 0x25, 0x71, 0x82
2019-03-04 18:46:28.102 Detail, Node019, Queuing (WakeUp) SensorBinaryCmd_Get (Node=19): 0x01, 0x09, 0x00, 0x13, 0x13, 0x02, 0x30, 0x02, 0x25, 0x72, 0x91
2019-03-04 18:46:28.102 Detail, Node019, Queuing (WakeUp) SensorMultilevelCmd_Get (Node=19): 0x01, 0x0a, 0x00, 0x13, 0x13, 0x03, 0x31, 0x04, 0x01, 0x25, 0x73, 0x94
2019-03-04 18:46:28.102 Detail, Node019, Queuing (WakeUp) SensorMultilevelCmd_Get (Node=19): 0x01, 0x0a, 0x00, 0x13, 0x13, 0x03, 0x31, 0x04, 0x03, 0x25, 0x74, 0x91
2019-03-04 18:46:28.103 Detail, Node019, Queuing (WakeUp) AlarmCmd_Get (Node=19): 0x01, 0x0c, 0x00, 0x13, 0x13, 0x05, 0x71, 0x04, 0x00, 0x07, 0x01, 0x25, 0x75, 0xd5
2019-03-04 18:46:28.103 Detail, Node019, Queuing (WakeUp) BatteryCmd_Get (Node=19): 0x01, 0x09, 0x00, 0x13, 0x13, 0x02, 0x80, 0x02, 0x25, 0x76, 0x25
2019-03-04 18:46:28.103 Detail, Node019, Queuing (Query) Query Stage Complete (Dynamic)
2019-03-04 18:46:28.103 Detail, Node019, Notification: Notification - Node Awake
Could you please help ?
