i am running ha on a green with sky connect with thread and zigbee. i want to change the channel that thread/zigbee is on but when i try to in the hardware section it says “unsupported_firmware”. does anyone know a solution.
thank you
Ryan
thank you
Ryan
It is no longer advised to use the multi-protocol firmware to run both thread and zigbee on the same dongle. It is better to have a dongle for thread, and a dongle for zigbee.
ok, my gut feeling is i need to restart the whole proccess with a new system to get it right, do you know if a yellow is worth using over a green/
If you have a green, no need to buy a yellow. Just add another dongle for thread.
