Can't configure Alexa Media Player after password change (500 Server got itself in trouble)
Hello there
I used Alexa Media Player for the last few months and everything was fine.
I recently changed my Amazon account password and want to reconfigure the integration Alexa Media Player. When I do so, filling in the intregration setup form, I am redirected to a page with an error 500
I’m using v4.4.0 of Alexa Media Player. Home Assistant 2023.1.1. My config is accessible from internet with SSL etc.
Anyone recently faced this?
In the logs I see this massive error trace:
2023-01-09 14:18:40.763 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.10/site-packages/httpcore/backends/asyncio.py", line 111, in connect_tcp
stream: anyio.abc.ByteStream = await anyio.connect_tcp(
File "/usr/local/lib/python3.10/site-packages/anyio/_core/_sockets.py", line 213, in connect_tcp
async with create_task_group() as tg:
File "/usr/local/lib/python3.10/site-packages/anyio/_backends/_asyncio.py", line 658, in __aexit__
raise CancelledError
asyncio.exceptions.CancelledError
File "/usr/local/lib/python3.10/site-packages/httpcore/_exceptions.py", line 10, in map_exceptions
yield
File "/usr/local/lib/python3.10/site-packages/httpcore/backends/asyncio.py", line 110, in connect_tcp
with anyio.fail_after(timeout):
File "/usr/local/lib/python3.10/site-packages/anyio/_core/_tasks.py", line 118, in __exit__
raise TimeoutError
TimeoutError
File "/usr/local/lib/python3.10/site-packages/httpx/_transports/default.py", line 60, in map_httpcore_exceptions
yield
File "/usr/local/lib/python3.10/site-packages/httpx/_transports/default.py", line 353, in handle_async_request
resp = await self._pool.handle_async_request(req)
File "/usr/local/lib/python3.10/site-packages/httpcore/_async/connection_pool.py", line 253, in handle_async_request
raise exc
File "/usr/local/lib/python3.10/site-packages/httpcore/_async/connection_pool.py", line 237, in handle_async_request
response = await connection.handle_async_request(request)
File "/usr/local/lib/python3.10/site-packages/httpcore/_async/connection.py", line 86, in handle_async_request
raise exc
File "/usr/local/lib/python3.10/site-packages/httpcore/_async/connection.py", line 63, in handle_async_request
stream = await self._connect(request)
File "/usr/local/lib/python3.10/site-packages/httpcore/_async/connection.py", line 111, in _connect
stream = await self._network_backend.connect_tcp(**kwargs)
File "/usr/local/lib/python3.10/site-packages/httpcore/backends/auto.py", line 29, in connect_tcp
return await self._backend.connect_tcp(
File "/usr/local/lib/python3.10/site-packages/httpcore/backends/asyncio.py", line 109, in connect_tcp
with map_exceptions(exc_map):
File "/usr/local/lib/python3.10/contextlib.py", line 153, in __exit__
self.gen.throw(typ, value, traceback)
File "/usr/local/lib/python3.10/site-packages/httpcore/_exceptions.py", line 14, in map_exceptions
raise to_exc(exc)
httpcore.ConnectTimeout
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 435, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_app.py", line 504, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_middlewares.py", line 117, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 227, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 81, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 236, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 136, in handle
result = await result
File "/config/custom_components/alexa_media/config_flow.py", line 883, in wrapped
return await cls.handler(request, **kwargs)
File "/usr/local/lib/python3.10/site-packages/authcaptureproxy/auth_capture_proxy.py", line 375, in all_handler
resp = await getattr(self.session, method)(
File "/usr/local/lib/python3.10/site-packages/httpx/_client.py", line 1848, in post
return await self.request(
File "/usr/local/lib/python3.10/site-packages/httpx/_client.py", line 1533, in request
return await self.send(request, auth=auth, follow_redirects=follow_redirects)
File "/usr/local/lib/python3.10/site-packages/httpx/_client.py", line 1620, in send
response = await self._send_handling_auth(
File "/usr/local/lib/python3.10/site-packages/httpx/_client.py", line 1648, in _send_handling_auth
response = await self._send_handling_redirects(
File "/usr/local/lib/python3.10/site-packages/httpx/_client.py", line 1685, in _send_handling_redirects
response = await self._send_single_request(request)
File "/usr/local/lib/python3.10/site-packages/httpx/_client.py", line 1722, in _send_single_request
response = await transport.handle_async_request(request)
File "/usr/local/lib/python3.10/site-packages/httpx/_transports/default.py", line 352, in handle_async_request
with map_httpcore_exceptions():
File "/usr/local/lib/python3.10/site-packages/httpx/_transports/default.py", line 77, in map_httpcore_exceptions
raise mapped_exc(message) from exc
httpx.ConnectTimeout
2023-01-09 14:18:56.724 ERROR (MainThread) [aiohttp.server] Error handling request
yield
raise TimeoutError
TimeoutError
yield
raise exc
raise exc
raise to_exc(exc)
Thanks in advance for your ideas!
Not a part of ha core. Post an issue here GitHub - custom-components/alexa_media_player: This is a custom component to allow control of Amazon Alexa devices in Home Assistant using the unofficial Alexa API.
Thanks for the feedback. There is an open issue with comments here: 500 Internal Server Error - during Authentication after OTP confirmation · Issue #1765 · custom-components/alexa_media_player · GitHub
How do I close the post?
Just leave it, people may find it and be able then to find the issue. All good.
In case someone comes here because of this issue, the key for me was to use the internal address to access homeassistant, not the public/internet facing one.
What do u mean?
When configuring the alexa player you do it from local http://homeassistant.local:8123/
So what’s your actual tip?
Cheers
I just cleared that error. I use chrome so i cleared everything history cashe and cookies and worked after that
I had the same problem, turned out to be Safari. I switched to Chrome and it worked fine.
Has this issue been corrected?
  1. I have NOT changed passwords…
    I have stood up a second instance of HA and am trying to get AMP installed there…
THX
-A
My Error…
Logger: aiohttp.server
Source: /usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py:451
First occurred: 9:22:15 AM (2 occurrences)
Last logged: 9:22:47 AM
File “/usr/local/lib/python3.13/site-packages/httpx/_transports/default.py”, line 72, in map_httpcore_exceptions
yield
File “/usr/local/lib/python3.13/site-packages/httpx/_transports/default.py”, line 377, in handle_async_request
File “/usr/local/lib/python3.13/site-packages/httpcore/_async/connection_pool.py”, line 216, in handle_async_request
raise exc from None
File “/usr/local/lib/python3.13/site-packages/httpcore/_async/connection_pool.py”, line 196, in handle_async_request
pool_request.request
File “/usr/local/lib/python3.13/site-packages/httpcore/_async/connection.py”, line 101, in handle_async_request
return await self._connection.handle_async_request(request)
File “/usr/local/lib/python3.13/site-packages/httpcore/_async/http11.py”, line 143, in handle_async_request
raise exc
File “/usr/local/lib/python3.13/site-packages/httpcore/_async/http11.py”, line 113, in handle_async_request
) = await self._receive_response_headers(**kwargs)
File “/usr/local/lib/python3.13/site-packages/httpcore/_async/http11.py”, line 186, in _receive_response_headers
event = await self._receive_event(timeout=timeout)
File “/usr/local/lib/python3.13/site-packages/httpcore/_async/http11.py”, line 224, in _receive_event
data = await self._network_stream.read(
self.READ_NUM_BYTES, timeout=timeout
File “/usr/local/lib/python3.13/site-packages/httpcore/_backends/anyio.py”, line 32, in read
File “/usr/local/lib/python3.13/contextlib.py”, line 162, in exit
self.gen.throw(value)
File “/usr/local/lib/python3.13/site-packages/httpcore/_exceptions.py”, line 14, in map_exceptions
raise to_exc(exc) from exc
httpcore.ReadTimeout
File “/usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py”, line 480, in _handle_request
File “/usr/local/lib/python3.13/site-packages/aiohttp/web_app.py”, line 569, in _handle
File “/usr/local/lib/python3.13/site-packages/aiohttp/web_middlewares.py”, line 117, in impl
File “/usr/src/homeassistant/homeassistant/components/http/security_filter.py”, line 92, in security_filter_middleware
File “/usr/src/homeassistant/homeassistant/components/http/forwarded.py”, line 83, in forwarded_middleware
File “/usr/src/homeassistant/homeassistant/components/http/request_context.py”, line 26, in request_context_middleware
File “/usr/src/homeassistant/homeassistant/components/http/ban.py”, line 86, in ban_middleware
File “/usr/src/homeassistant/homeassistant/components/http/auth.py”, line 242, in auth_middleware
File “/usr/src/homeassistant/homeassistant/components/http/headers.py”, line 32, in headers_middleware
response = await handler(request)
File “/usr/src/homeassistant/homeassistant/helpers/http.py”, line 73, in handle
result = await handler(request, **request.match_info)
File “/config/custom_components/alexa_media/config_flow.py”, line 1049, in wrapped
File “/usr/local/lib/python3.13/site-packages/authcaptureproxy/auth_capture_proxy.py”, line 442, in all_handler
site, data=data, headers=headers, follow_redirects=True
File “/usr/local/lib/python3.13/site-packages/httpx/_client.py”, line 1905, in post
…<13 lines>…
File “/usr/local/lib/python3.13/site-packages/httpx/_client.py”, line 1585, in request
File “/usr/local/lib/python3.13/site-packages/httpx/_client.py”, line 1674, in send
…<4 lines>…
File “/usr/local/lib/python3.13/site-packages/httpx/_client.py”, line 1702, in _send_handling_auth
…<3 lines>…
File “/usr/local/lib/python3.13/site-packages/httpx/_client.py”, line 1739, in _send_handling_redirects
File “/usr/local/lib/python3.13/site-packages/httpx/_client.py”, line 1776, in _send_single_request
File “/usr/local/lib/python3.13/site-packages/httpx/_transports/default.py”, line 376, in handle_async_request
File “/usr/local/lib/python3.13/site-packages/httpx/_transports/default.py”, line 89, in map_httpcore_exceptions
httpx.ReadTimeout
This should be asked on the owners GitHub.
Wanted to add my experience in case anyone is checking this in 2025 or beyond. I tried various fixes I read in different threads and this one, including installing alexapy, using local home assistant address vs public, different browser, clearing cache, etc. and nothing worked.
What finally got it to work was simply going through the process of setting up 2FA for my Amazon account and copy/pasting the key into the 2SV field. (Keep in mind you will need to view and copy the key BEFORE finalizing the 2-factor setup, or else you won’t be able to access the key and will have to reconfigure 2FA).
It says that the 2SV key is optional, but for me that was the only thing that got me around the 500 Server Error. Hope this helps someone!
I battled this exact problem w/ the same errors & logs for over a month now. If you have a business Amazon account tied to your personal account, you MUST use your personal account credentials, not the biz one. That’s what caused my issues.
working fine now.
Made an account just say thank you, and to boost your message.
This is the way to do it! Made a 2FA and in the Web UI it asked me for the code, were previously it just showed white webpage with Alexa on top.
Now it works, thank you again!
