Just installed HA on a S12 Pro N100. Got it up and running, created an account and it is plugged in via Ethernet.
However trying to configure WIFI (do I even need to?) it fails. I have tried in the UI and connecting to a K/M and via the command line.
When I search for the network in HA I can see my SSID. Signal strength is 100. I choose WPA-PSK and use the password. The hit save.
Then it says "Failed to change network settings
Activating connection failed, check connection settings."
When I tried doing this manually using this
Command: network update WIRELESSINTERFACENAMEHERE --ipv4-method auto --ipv6-method auto --wifi-auth wpa-psk --wifi-mode infrastructure --wifi-ssid WIFI-NAME --wifi-psk WIFI-PASSWORD
The image shows the errors
Do I even need to use wifi if this will always be in Ethernet?
I figure I do need it as I can’t connect to the server in the iOS app and I cant connect to the SMLIGHT SLZB-06 device either and before I go to far want to get this fixed.
