Can't connect anymore with the App or browser through local network
HA has been working fine for years, and it still does in the background, but suddenly I can’t access anymore to the web interface.
My home router config didn’t change. I used to be able to connect with http://192.168.1.12:8123 but no more. I can still ping this IP, and I confirm it is still allocated to the mac address of the Rpi, but it won’t load the web interface, on my phone or a PC connected to the local network. I’m puzzled.
I’ve tried SSH with putty and a private key created long ago, but it won’t connect either.
In the background the automations continue to work. Does anyone have a miracle idea?
thanks
Hi Jerome, have you connected a display to your RPi?
What kind of installation method are you running?
Hello, I have HAOS, but right, plugin a screen will be the next step. However I need to open the case and of course the problem appeared the day before vacations, so I had no time so far. Back next week with some update.
I also use an external SSD instead of an sd-card, maybe I can find some tool for testing it.
answering to myself: Finally I could restore a backup and everything is back on track. In the end I think it was a combination of many things in parallel: changed the duckdns config because access from outside was KO, update HA and add-ons, lost the private key to connect with SSH, and I suspected the SSD to have issues…
That allowed me to test the HA restore function and as usual with HA, this is rock solid.
And in parallel I have understood why connection from the outside was not working anymore: this is because of Internet provider who switched my connection to IPv6 and IPv4 CGNAT. I have asked for a rollback to full IPv4, which should solve the problem.
There you go: multiple reasons, good you found/solved it!
Please take the time to mark the solution as the answer, you do that by selecting the three dots under the post:
Then select the check box:
By doing so:
  • this thread can be useful to other users as well (this thread comes up as solution when starting a thread which is similar to yours).
  • this prevents that someone else steps in trying to help
Thanks for giving back to the community! :+1:
