I am trying to connect my Aqara M2 hub to Home Assistant via Matter. I attempt to connect using the HA mobile app, but it always says something went wrong. I have my phone and the M2 hub connected to the same network with access to HA. I have enabled ipv6 in HA. Any help would be greatly appreciated.
The log for the Matter add-on shows this:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service banner: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
Add-on: Matter Server
Matter WebSocket Server for Home Assistant Matter support.
Add-on version: 5.4.0
You are running the latest version of this add-on.
System: Home Assistant OS 12.0 (amd64 / qemux86-64)
Home Assistant Core: 2024.2.5
Home Assistant Supervisor: 2024.02.1
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service banner successfully started
s6-rc: info: service matter-server: starting
s6-rc: info: service matter-server successfully started
s6-rc: info: service legacy-services: starting
[15:45:14] INFO: Starting Matter Server...
s6-rc: info: service legacy-services successfully started
[15:45:14] INFO: Using 'enp6s18' as primary network interface.
[15:45:14] INFO: Successfully send discovery information to Home Assistant.
2024-03-01 15:45:15 (MainThread) INFO [matter_server.server.stack] Initializing CHIP/Matter Logging...
[1709336715.101769][126:126] CHIP:CTL: Setting attestation nonce to random value
[1709336715.101941][126:126] CHIP:CTL: Setting CSR nonce to random value
2024-03-01 15:45:15 (MainThread) INFO [matter_server.server.stack] Initializing CHIP/Matter Controller Stack...
2024-03-01 15:45:15 (MainThread) CHIP_ERROR [chip.native.DL] Failed to get WiFi interface
2024-03-01 15:45:15 (MainThread) CHIP_ERROR [chip.native.DL] Failed to reset WiFi statistic counts
2024-03-01 15:45:15 (MainThread) WARNING [PersistentStorage] Initializing persistent storage from file: /data/chip.json
2024-03-01 15:45:15 (MainThread) WARNING [PersistentStorage] Loading configuration from /data/chip.json...
2024-03-01 15:45:15 (MainThread) WARNING [CertificateAuthorityManager] Loading certificate authorities from storage...
2024-03-01 15:45:15 (MainThread) WARNING [CertificateAuthority] New CertificateAuthority at index 1
2024-03-01 15:45:15 (MainThread) WARNING [CertificateAuthority] Loading fabric admins from storage...
2024-03-01 15:45:15 (MainThread) WARNING [FabricAdmin] New FabricAdmin: FabricId: 0x0000000000000002, VendorId = 0x134B
2024-03-01 15:45:15 (MainThread) INFO [matter_server.server.stack] CHIP Controller Stack initialized.
2024-03-01 15:45:15 (MainThread) INFO [matter_server.server.server] Starting the Matter Server...
2024-03-01 15:45:15 (MainThread) INFO [matter_server.server.helpers.paa_certificates] Fetching the latest PAA root certificates from DCL.
2024-03-01 15:45:15 (ThreadPoolExecutor-0_0) WARNING [py.warnings] /usr/local/lib/python3.11/concurrent/futures/thread.py:58: CryptographyDeprecationWarning: The parsed certificate contains a NULL parameter value in its signature algorithm parameters. This is invalid and will be rejected in a future version of cryptography. If this certificate was created via Java, please upgrade to JDK21+ or the latest JDK11/17 once a fix is issued. If this certificate was created in some other fashion please report the issue to the cryptography issue tracker. See https://github.com/pyca/cryptography/issues/8996 and https://github.com/pyca/cryptography/issues/9253 for more details.
2024-03-01 15:45:20 (MainThread) INFO [matter_server.server.helpers.paa_certificates] Fetched 129 PAA root certificates from DCL.
2024-03-01 15:45:20 (MainThread) INFO [matter_server.server.helpers.paa_certificates] Fetching the latest PAA root certificates from Git.
2024-03-01 15:45:21 (MainThread) INFO [matter_server.server.helpers.paa_certificates] Fetched 90 PAA root certificates from Git.
2024-03-01 15:45:21 (MainThread) WARNING [FabricAdmin] Allocating new controller with CaIndex: 1, FabricId: 0x0000000000000002, NodeId: 0x000000000001B669, CatTags: []
2024-03-01 15:45:22 (Dummy-2) CHIP_ERROR [chip.native.DL] Long dispatch time: 119 ms, for event type 2
2024-03-01 15:45:22 (MainThread) INFO [matter_server.server.device_controller] Loaded 0 nodes from stored configuration
2024-03-01 15:45:22 (MainThread) INFO [matter_server.server.vendor_info] Loading vendor info from storage.
2024-03-01 15:45:22 (MainThread) INFO [matter_server.server.vendor_info] Loaded 172 vendors from storage.
2024-03-01 15:45:22 (MainThread) INFO [matter_server.server.vendor_info] Fetching the latest vendor info from DCL.
2024-03-01 15:45:22 (MainThread) INFO [matter_server.server.vendor_info] Fetched 170 vendors from DCL.
2024-03-01 15:45:22 (MainThread) INFO [matter_server.server.vendor_info] Saving vendor info to storage.
2024-03-04 09:00:12 (MainThread) INFO [matter_server.server.device_controller] Starting Matter commissioning using Node ID 11 and IP fe80::56ef:44ff:fe60:8174%enp6s18 (attempt 1/3).
2024-03-04 09:00:13 (Dummy-2) CHIP_ERROR [chip.native.DL] Long dispatch time: 236 ms, for event type 2
2024-03-04 09:00:16 (Dummy-2) CHIP_ERROR [chip.native.EM] Failed to Send CHIP MessageCounter:122680580 on exchange 5632i sendCount: 4 max retries: 4
2024-03-04 09:00:19 (Dummy-2) CHIP_ERROR [chip.native.SC] PASESession timed out while waiting for a response from the peer. Expected message type was 33
2024-03-04 09:00:19 (Dummy-2) CHIP_ERROR [chip.native.ZCL] Secure Pairing Failed
2024-03-04 09:00:24 (MainThread) INFO [matter_server.server.device_controller] Starting Matter commissioning using Node ID 11 and IP fe80::56ef:44ff:fe60:8174%enp6s18 (attempt 2/3).
2024-03-04 09:00:28 (Dummy-2) CHIP_ERROR [chip.native.EM] Failed to Send CHIP MessageCounter:122680581 on exchange 5633i sendCount: 4 max retries: 4
2024-03-04 09:00:30 (Dummy-2) CHIP_ERROR [chip.native.SC] PASESession timed out while waiting for a response from the peer. Expected message type was 33
2024-03-04 09:00:30 (Dummy-2) CHIP_ERROR [chip.native.ZCL] Secure Pairing Failed
2024-03-04 09:00:35 (MainThread) INFO [matter_server.server.device_controller] Starting Matter commissioning using Node ID 11 and IP fe80::56ef:44ff:fe60:8174%enp6s18 (attempt 3/3).
2024-03-04 09:00:39 (Dummy-2) CHIP_ERROR [chip.native.EM] Failed to Send CHIP MessageCounter:122680582 on exchange 5634i sendCount: 4 max retries: 4
2024-03-04 09:00:41 (Dummy-2) CHIP_ERROR [chip.native.SC] PASESession timed out while waiting for a response from the peer. Expected message type was 33
2024-03-04 09:00:41 (Dummy-2) CHIP_ERROR [chip.native.ZCL] Secure Pairing Failed
2024-03-04 09:00:41 (MainThread) ERROR [matter_server.server.client_handler] [140453958432464] SDK Error during handling message: commission_on_network: Commissioning failed for node 11.
