Alex95
January 1, 2024, 3:58pm
1
Hi All,
HA detects my Denon Ceol N10 amplifier but when trying to connect to the ‘Denon AVR’ integration, it fails:
Failed to connect, please try again, disconnecting mains power and ethernet cables and reconnecting them may help
I tried many times to disconnect the main power, ethernet cable, reset the amplifier, but still no success.
On the other hand, it connects to the HEOS integration (but I can’t turn on / turn off the device here…)
Did any one succeed to connect a recent Denon CEOL amplifer to this integration?
Thanks for your feedback!
iddibum
(Iddibum)
January 31, 2024, 7:12pm
2
Hello
Now, i cannot connect my Denon N10 with HA.
Because, “Please confirm the addition of the receiver”.
Network control is on.
But how can I confirm this?
please help…
I have the same problem with my Denon CEOL N12
Alex95
March 10, 2024, 2:47pm
4
I found a way to connect my CEOL N10 to HA.
To turn the device on and off, use the switch entity that should be called switch.denon_ceol or something similar. You can find it in Settings → Devices & services → Entities and it is easy to add it to your user interface or in an automation.
For the volume, I use 2 scripts as follows:
alias: denon_volume_down
sequence:
- service: media_player.volume_set
entity_id: media_player.denon_ceol
volume_level: >-
{{ state_attr('media_player.denon_ceol', 'volume_level') | float - 0.01
mode: single
and
alias: denon_volume_up
sequence:
volume_level: >-
{{ state_attr('media_player.denon_ceol', 'volume_level') | float + 0.01
mode: single
These scripts can be triggered via an automation or behind a button in the user interface.
Not the easiest way to control your device, but it works!
