Can't connect Fibaro device to AeoTec Z-Stick 7
Hey,
first of all excuse my use of language - I’m not a native speaker.
Now the story regarding my Problem:
Im trying to connect a Fibaro Walli Rolloshutter - the one that sits on the wall and not inside it - to my AeoTec Z-Stick 7.
In the beginning my Homeassistant didn’t even discover the Z-Stick, so to start I made a firmware update using Simplicity Studio. Said and done the Homeassistant now discovers the stick and lets me configure it. To my eye the integration works fine.
My problem now is, that i may be able to start the pairing process in HomeAssistant, but the integration either discovers nothing or gives me an error, saying somthing along the lines like"The device pairing wasn’t successful. Have a look at the logs" - Problem: Logs don’t show anything…
Has anybody an idea how to fix this problem?
Im running HomeAssistant in its newest version on an x64 machine - If thats of any interest to you
Other modules that I use are ConBee II and the HA Skynet Stick.
I don’t have any great suggestions other than to try another z-wave device to see if it is that device or the overall setup. I have generally found the fibaro devices to be highly reliable. -David
:slight_smile: did you manage too solve the connecting error? I’am having the same issue…:slight_smile:
