I’ve got a Philips hue hub v2 with latest firmware and I can’t get haas to connect to it . This is a cross post from the sub-reddit.
The ip address is fine
When I launch Haas I get the configure hue card
I click configure
I press the button on the hub
I click the “I’ve pressed the button” button
Dialogue goes away and phue.conf saved
Running on Mac OS X
However haas still won’t connect to hue. In the terminal window I get… attempting to connect to the bridge Using Using username from.config ERROR: Cannot reach the bridge.
I’ve queried the Hue Hub using the built in API and the username stored in the phue.conf is valid and registered…
Any ideas greatly appreciated!
This is the error I’m getting:
16-09-10 11:15:56 homeassistant.components.light.hue: Cannot reach the bridge Traceback (most recent call last): File “/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/sitepackages/homeassistant/components/light/hue.py”, line 123, in update_lights api = bridge.get_api()
File “/Users/k*/.homeassistant/deps/phue.py”, line 615, in get_api return self.request(‘GET’, ‘/api/’ + self.username) File “/Users/k*/.homeassistant/deps/phue.py”, line 472, in request return json.loads(str(result.read(), encoding=‘utf-8’)) File “/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/http/client.py”, line 458, in read s = self.fp.read() File “/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/socket.py”, line 575, in readinto return self._sock.recv_into(b) socket.timeout: timed out
