Can't connect iOS app to HomeAssistant: Error: Invalid client id or redirect uri
Hello, I can’t connect Home Assistant to the iOS app.
I’m running Home Assistant 0.97.2 on my Mac. I disabled ipv6 and I use DuckDNS to get a domain with Let’s Encrypt HTTPS.
I get the following error:
The log shows the following:
2019-08-26 16:54:15 ERROR (MainThread) [homeassistant.components.auth.indieauth] OS error while looking up redirect_uri https://home-assistant.io/iOS: No route to host
2019-08-26 16:54:15 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 10.100.102.1
Hi all, been bashing my head against this one all night… Ended up nuking my config directories as I blamed a recent errant “rm -r *” in my .homeassistant directory for creating some form of instability, but was wrong. New installation, old problems.
In the end I managed to trace it back to a self-compiled installation of openssl. I use a RPi3, and it didn’t have the latest openssl available as a package which was causing me some problems with either HA or something else a while back. The issue with this is that it tries to load the root certificates from /usr/local/ssl/certs and NOT /etc/ssl/certs (which is where update-ca-certificates is plonking the certificates)
Not wanting to figure out how to configure either update-ca-certificates or how to compileopenssl against the correct dirrectory, cheating and creating a symlink worked for me:
rm /usr/local/ssl/certs -r
ln -s /etc/ssl/certs /usr/local/ssl/certs
hope this helps someone
You’re a lifesaver, this fixed my login issues after manually compiling openssl on raspbian stretch.
Great.It’s work.
