I am having trouble connecting my Nanoleaf Essentials LED strip, Eve Smart Switch or smart window sensors with Home Assistant.
When I go to connect, previously the screen stuck on “checking network connection” (no idea if this is the exact translation, but after the last update I get the message "cannot connect to (the name of my Thread Router).
What have I already tried?
- Other device to pair;
- Google Play Services data removed;
- Google Home reinstalled;
- Clean install of Home Assistant
So far nothing has helped, that’s why I created this topic. I hope you can help me further.
Information:
- Home Assistant OS in Proxmox VM;
- Matter Server 6.3.1 (latest version at time of writing);
- OpenThread Border Router 2.9.0 (latest version at time of writing);
- Thread integration;
- Matter (BETA);
- SkyConnect USB.
I’m not running the multiprotocol version, only Thread.
Logs
Matter Server Logs
2024-07-22 13:08:22.900 (MainThread) WARNING [PersistentStorage] Initializing persistent storage from file: /data/chip.json
2024-07-22 13:08:22.901 (MainThread) WARNING [PersistentStorage] Loading configuration from /data/chip.json...
2024-07-22 13:08:22.947 (MainThread) WARNING [CertificateAuthorityManager] Loading certificate authorities from storage...
2024-07-22 13:08:22.947 (MainThread) WARNING [CertificateAuthority] New CertificateAuthority at index 1
2024-07-22 13:08:22.948 (MainThread) WARNING [CertificateAuthority] Loading fabric admins from storage...
2024-07-22 13:08:22.948 (MainThread) WARNING [FabricAdmin] New FabricAdmin: FabricId: 0x0000000000000002, VendorId = 0x134B
2024-07-22 13:08:22.948 (MainThread) INFO [matter_server.server.stack] CHIP Controller Stack initialized.
2024-07-22 13:08:22.948 (MainThread) INFO [matter_server.server.server] Starting the Matter Server...
2024-07-22 13:08:22.950 (MainThread) INFO [matter_server.server.helpers.paa_certificates] Skip fetching certificates (already fetched within the last 24h).
2024-07-22 13:08:22.950 (MainThread) WARNING [FabricAdmin] Allocating new controller with CaIndex: 1, FabricId: 0x0000000000000002, NodeId: 0x000000000001B669, CatTags: []
2024-07-22 13:08:22.992 (MainThread) INFO [matter_server.server.device_controller] Loaded 0 nodes from stored configuration
2024-07-22 13:08:22.996 (MainThread) INFO [matter_server.server.vendor_info] Loading vendor info from storage.
2024-07-22 13:08:22.998 (MainThread) INFO [matter_server.server.vendor_info] Loaded 226 vendors from storage.
2024-07-22 13:08:22.998 (MainThread) INFO [matter_server.server.vendor_info] Fetching the latest vendor info from DCL.
2024-07-22 13:08:23.179 (MainThread) INFO [matter_server.server.vendor_info] Fetched 224 vendors from DCL.
2024-07-22 13:08:23.179 (MainThread) INFO [matter_server.server.vendor_info] Saving vendor info to storage.
OTBR Logs
00:00:36.589 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:57.530 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:01:22.152 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:02:00.548 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:02:09.140 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:02:18.862 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:02:32.344 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:02:46.548 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:02:57.083 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:03:09.971 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:03:20.261 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:03:32.178 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:03:47.746 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:03:57.738 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:04:12.785 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:04:24.806 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:04:36.490 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
If I have forgotten to mention something, please let me know and I will add it to this post.
Thank you very much in advance for the help ![]()
