Hi everyone,
I am trying to create a simple test automation to send some data from the home assistant to my AWS environment. I have created a Thing in AWS IoT Core and loaded the cert and private key into a specific directory.
This is my configuration.yaml file:
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
# Configurazione MQTT
mqtt:
broker: "XXXXXXXX.iot.eu-west-1.amazonaws.com"
port: 8883
tls_insecure: false
protocol: 3.1
client_cert: "path to local certificate.pem.crt"
client_key: "path to local private.pem.key"
certificate: "path to local AmazonRootCA1.pem"
and this is my vanilla automations.yaml:
- alias: Send Data to AWS IoT
- platform: time_pattern
seconds: '/10'
- service: mqtt.publish
topic: "aws-iot/test-topic"
payload_template: '{"topic": "aws-iot/test-topic", "timestamp": "{{ as_timestamp(now()) }}"}'
I have not configured anything in the Devices and Services menu since I’ve read that it is not necessary for AWS IoT to pass through mosquitto or another mqtt configuration if you set it up through configuration.yaml.
However, when I restart my device I get this error for the automation:
The automation “Send Data to AWS IoT” (
automation.send_data_to_aws_iot) has an unknown action:mqtt.publish.
This error prevents the automation from running correctly. Maybe this action is no longer available, or perhaps a typo caused it.
and if I let Home Assistant built-in tool check my yaml file I find out that it has the following errors:
Can someone help me? I’ve tried my best but I am not able to troubleshoot this by myself.
Any help would be very appreciated,
thanks
