Cant connect on homeassistat with ip adress
I’ve tried to connect via my ip address which is on homeassistant. But I can’t get in with this. I’ve tried to change addresses from my supplier and my rasberry pi. But nothing works. I saw a post in here about ip address 255.255.255.0. What is this? And should this be dialed in somewhere? Find this in my settings on my wifi network. Homeassistant has access there. But I’m connected by cable. So this shouldn’t matter. Which place should these addresses be?? on wlano or endo? Should I connect directly to the provider’s router or is it fine to connect to ports on the wifi network?
