Can't connect through duckdns (solved in posts 5 & 6)
It’s been weeks since my DuckDns domain has been able to connect to my Home Assistant. I am wondering if I have a problem with Lets Encrypt. According to Remote access for Home Assistant:
After you check your configuration from the command line and then restart Home Assistant you’ll need to use https:// to access your system, even from your local network.
Now is a good time to check that you can access it using https:// - knowing it works will help you later if you run into issues.
But, https does not work here:
http://192.168.1.57:8123/ opens Home Assistant.
https://192.168.1.57:8123/ returns:
This site can’t provide a secure connection
192.168.1.57 sent an invalid response.
My current Lets Encrypt configuration is as created by installing the DuckDns add-on:
accept_terms: true
algo: secp384r1
certfile: fullchain.pem
keyfile: privkey.pem
I also tried (based on the information here):
accept_terms: true
algo: secp384r1
certfile: /ssl/fullchain.pem
keyfile: /ssl/privkey.pem
Neither works.
Any ideas for troubleshooting?
Note: in one of my earlier attempts to fix this, I deleted the DuckDns add-on and reinstalled it.
Iit sounds like you didn’t add the required lines to http:, see All SSL types in the guide you followed.
Thanks. This is certainly more progress than I’ve made on my own. I appreciate the assistance.
Now, http://192.168.1.57:8123 returns, as expected:
This page isn’t working
192.168.1.57 didn’t send any data.
Curiously, https://192.168.1.57:8123 returns
This server could not prove that it is 192.168.1.57; its security certificate is from sxxx.duckdns.org.
('xxx’is my DuckDns domain)
BUT, https://xxx.duckdns.org:/8123 does work on my local network and off network. This is real progress!
Now the bad news?
Upon restarting Home Assistant, I am getting an “Invalid Config” notification:
Invalid config
The following integrations and platforms could not be set up:
ssdp (Show logs)
dlna_dms (Show logs)
default_config (Show logs)
And the logs:
Logger: homeassistant.setup
Source: setup.py:205
First occurred: 2:43:22 PM (2 occurrences)
Last logged: 2:43:25 PM
Setup failed for dlna_dms: (DependencyError(…), ‘Could not setup dependencies: ssdp’)
Setup failed for default_config: (DependencyError(…), ‘Could not setup dependencies: ssdp’)
Logger: homeassistant.components.cert_expiry
Source: helpers/update_coordinator.py:215
Integration: Certificate Expiry (documentation, issues)
First occurred: 2:43:41 PM (1 occurrences)
Last logged: 2:43:41 PM
Error fetching xxx.duckdns.org data: Connection refused by server: xxx.duckdns.org:443
Do these errors mean anything to you?
You need to check the log file for information about why ssdp wasn’t set up.
Earlier you said you needed to use port 8123… so that’s why that’s failing :wink:
I understood that I need both ports 443 and 8123 forwarded in my router. However, I looked at the router again and I had port 443 going to 8123. I changed it to 443 -to- 443 and that error is gone.
On the other errors. The log files don’t tell me much (and they are off-topic for my DuckDns question). But here is my log file. If you have any tips for me, thank you. Otherwise, I will mark the thread as solved.
Home Assistant Core
Unable to set up dependencies of dlna_dms. Setup failed for dependencies: ssdp
10:42:57 PM – (ERROR) setup.py - message first occurred at 10:42:55 PM and shows up 5 times
10:42:43 PM – (ERROR) setup.py - message first occurred at 10:42:40 PM and shows up 2 times
Error handling when_setup callback for frontend
10:42:33 PM – (ERROR) helpers/network.py - message first occurred at 10:42:33 PM and shows up 2 times
dlna_dms
dlna_dms = DLNA Digital Media Server integration
I have a lot of Alexa Echo devices that integrate as media_player.xxx and they all appear to be working.
The first occurrence of this error:
Log Details (ERROR)
Source: setup.py:381
First occurred: 10:42:55 PM (5 occurrences)
Last logged: 10:42:57 PM
Unable to set up dependencies of upnp. Setup failed for dependencies: ssdp
ssdp
ssdp = Simple Service Discovery Protocol (part of UPnP)
The only integration I have on the list in the documentation is my Samsung phone, and the integration appears to be working.
You (still) need to look in the file on disk, home-assistant.log, and look for the first mention of ssdp to find out why SSDP is failing. Once you fix that the other problems will go away.
I am starting a new thread since this has nothing to do with the original topic.
