Can't connect thru ip:8123
Hi, I hope i’am on the right topic.
I have home assistant running for some time. I have a nice dashboard that I could see with IP:8123.
I connected a esp8266 with mqtt what was working perfectly , but after some program changes the esp was in a connection loop mqtt connection on and off.
Then the home assistant problem started. I could not restart home assistant from system tab in the dashboard.
So I restart home assistant with a power down of the raspberry pi 3+.
The raspberry pi restart and home assistant is running. Also the observer is healthy.
The zigbee buttons in the living are working .
I can see the IP of the raspberry in wnetwatcher.
I can ping the IP.
But I can’t connect to IP:8123 anymore to see the dashboard.
I get in the browser =>
this page is not working
192.168.1.xxx has not sent any data
ERR_EMPTY_RESPONSE
What I also did, is adding duckdns to home assistant.
Therefore I have to add,
This in configuration.yaml
http:
  ssl_certificate: /ssl/fullchain.pem
  ssl_key: /ssl/privkey.pem
  ip_ban_enabled: true
  login_attempts_threshold: 6
What can I do to view the dashboard again?
Many thanks to help.
Peter
Are you using https in the url instead of http now?
no, I used the same address as before. So, tried with the https:// ip:8123 and now it works.
if I delete the extra lines in configuration.yaml then it works like before.
Do I need those lines for duckdns to work? Or can duckdns works without?
Many thanks.
If you do not understand what those lines do, and why you need them, I would respectfully suggest that you spend some time learning more about the system instead of just blindly pushing buttons. Having a better understanding will make your journey much more successful, and much less frustrating.
This video covers duckdns and certificates and dns and may help you in this regard:
Many thanks for your response. I will have a look tomorrow.
Best regards.
