Only one, but because it worked OK before, I uninstalled it and then installed it again. No errors in the log
2021-12-10 23:06:18,869 INFO 200 GET /static/js/vendor/materialize/materialize.min.js?hash=4be20daf (0.0.0.0) 8.69ms
2021-12-10 23:06:18,878 INFO 200 GET /static/js/vendor/ace/ace.js?hash=65322f49 (0.0.0.0) 5.80ms
2021-12-10 23:06:18,894 INFO 200 GET /static/js/esphome/index-e0440f6f.js (0.0.0.0) 3.76ms
2021-12-10 23:06:19,125 INFO 200 GET /static/fonts/material-icons/MaterialIcons-Regular.woff2 (0.0.0.0) 1.36ms
2021-12-10 23:06:19,258 INFO 200 GET /static/js/vendor/ace/theme-dreamweaver.js (0.0.0.0) 1.64ms
2021-12-10 23:06:19,262 INFO 200 GET /static/js/vendor/ace/mode-yaml.js (0.0.0.0) 1.98ms
2021-12-10 23:06:19,278 INFO 200 GET /devices (0.0.0.0) 1.82ms
2021-12-10 23:06:19,310 INFO 200 GET /static/images/favicon.ico?hash=2655a073 (0.0.0.0) 1.40ms
2021-12-10 23:06:19,364 INFO 101 GET /ace (0.0.0.0) 0.94ms
2021-12-10 23:06:19,366 INFO Running command ‘esphome --dashboard -q vscode --ace /config/esphome’
2021-12-10 23:09:40,188 INFO 200 GET / (0.0.0.0) 3.20ms
2021-12-10 23:09:40,217 INFO 200 GET /static/fonts/material-icons/material-icons.css?hash=ead4c276 (0.0.0.0) 3.92ms
2021-12-10 23:09:40,236 INFO 200 GET /static/js/vendor/jquery/jquery.min.js?hash=12108007 (0.0.0.0) 7.08ms
2021-12-10 23:09:40,240 INFO 200 GET /static/css/vendor/materialize/materialize.min.css?hash=ec1df3ba (0.0.0.0) 9.13ms
2021-12-10 23:09:40,250 INFO 200 GET /static/css/esphome-2.css?hash=95c08d5a (0.0.0.0) 6.37ms
2021-12-10 23:09:40,255 INFO 200 GET /static/js/vendor/jquery-ui/jquery-ui.min.js?hash=cab3392d (0.0.0.0) 8.92ms
2021-12-10 23:09:40,270 INFO 200 GET /static/js/vendor/materialize/materialize.min.js?hash=4be20daf (0.0.0.0) 10.56ms
2021-12-10 23:09:40,273 INFO 200 GET /static/js/vendor/jquery-validate/jquery.validate.min.js?hash=aad785d4 (0.0.0.0) 8.04ms
2021-12-10 23:09:40,280 INFO 200 GET /static/js/vendor/ace/ace.js?hash=65322f49 (0.0.0.0) 4.86ms
2021-12-10 23:09:40,447 INFO 200 GET /static/js/esphome/index-e0440f6f.js (0.0.0.0) 3.69ms
2021-12-10 23:09:40,917 INFO 200 GET /static/fonts/material-icons/MaterialIcons-Regular.woff2 (0.0.0.0) 1.38ms
2021-12-10 23:09:41,145 INFO 200 GET /static/js/vendor/ace/theme-dreamweaver.js (0.0.0.0) 1.69ms
2021-12-10 23:09:41,149 INFO 200 GET /static/js/vendor/ace/mode-yaml.js (0.0.0.0) 2.02ms
2021-12-10 23:09:41,166 INFO 200 GET /devices (0.0.0.0) 1.84ms
2021-12-10 23:09:41,185 INFO 200 GET /static/images/favicon.ico?hash=2655a073 (0.0.0.0) 1.82ms
2021-12-10 23:09:41,194 INFO 101 GET /ace (0.0.0.0) 0.93ms
2021-12-10 23:09:41,213 INFO Running command ‘esphome --dashboard -q vscode --ace /config/esphome’
2021-12-11 13:16:34,366 INFO 200 GET / (0.0.0.0) 1.37ms
2021-12-11 13:16:34,394 INFO 200 GET /static/fonts/material-icons/material-icons.css?hash=ead4c276 (0.0.0.0) 2.16ms
2021-12-11 13:16:34,406 INFO 200 GET /static/css/esphome-2.css?hash=95c08d5a (0.0.0.0) 2.19ms
2021-12-11 13:16:34,411 INFO 200 GET /static/css/vendor/materialize/materialize.min.css?hash=ec1df3ba (0.0.0.0) 2.84ms
2021-12-11 13:16:34,421 INFO 200 GET /static/js/vendor/jquery-validate/jquery.validate.min.js?hash=aad785d4 (0.0.0.0) 2.45ms
2021-12-11 13:16:34,425 INFO 200 GET /static/js/vendor/jquery/jquery.min.js?hash=12108007 (0.0.0.0) 2.41ms
2021-12-11 13:16:34,430 INFO 200 GET /static/js/vendor/jquery-ui/jquery-ui.min.js?hash=cab3392d (0.0.0.0) 2.11ms
2021-12-11 13:16:34,437 INFO 200 GET /static/js/vendor/materialize/materialize.min.js?hash=4be20daf (0.0.0.0) 2.19ms
2021-12-11 13:16:34,446 INFO 200 GET /static/js/vendor/ace/ace.js?hash=65322f49 (0.0.0.0) 6.02ms
2021-12-11 13:16:34,465 INFO 200 GET /static/js/esphome/index-e0440f6f.js (0.0.0.0) 4.16ms
2021-12-11 13:16:35,107 INFO 200 GET /static/fonts/material-icons/MaterialIcons-Regular.woff2 (0.0.0.0) 2.01ms
2021-12-11 13:16:35,112 INFO 200 GET /static/js/vendor/ace/theme-dreamweaver.js (0.0.0.0) 2.16ms
2021-12-11 13:16:35,118 INFO 200 GET /static/js/vendor/ace/mode-yaml.js (0.0.0.0) 2.08ms
2021-12-11 13:16:35,125 INFO 200 GET /static/images/favicon.ico?hash=2655a073 (0.0.0.0) 2.22ms
2021-12-11 13:16:35,139 INFO 200 GET /devices (0.0.0.0) 4.40ms
2021-12-11 13:16:35,144 INFO 101 GET /ace (0.0.0.0) 1.68ms
2021-12-11 13:16:35,146 INFO Running command ‘esphome --dashboard -q vscode --ace /config/esphome’
2021-12-11 13:16:36,654 INFO 200 GET /static/js/esphome/c.8c24b434.js (0.0.0.0) 2.64ms
2021-12-11 13:16:36,681 INFO 200 GET /static/js/esphome/c.9fbc2162.js (0.0.0.0) 2.35ms
2021-12-11 13:16:36,688 INFO 200 GET /static/js/esphome/c.2cdbdbed.js (0.0.0.0) 3.66ms
2021-12-11 13:16:36,694 INFO 200 GET /static/js/esphome/c.42357ee2.js (0.0.0.0) 3.52ms
2021-12-11 13:16:36,704 INFO 200 GET /static/js/esphome/c.82ae9110.js (0.0.0.0) 5.86ms
2021-12-11 13:16:36,805 INFO 200 GET /static/js/esphome/c.ae5497fd.js (0.0.0.0) 1.78ms
2021-12-11 13:16:36,853 INFO 101 GET /logs (0.0.0.0) 1.32ms
2021-12-11 13:16:36,855 INFO Running command ‘esphome --dashboard logs /config/esphome/paddestoelen-regelaar.yaml --device OTA’
2021-12-11 13:16:39,906 INFO 304 GET /devices (0.0.0.0) 3.81ms
2021-12-11 13:16:44,920 INFO 304 GET /devices (0.0.0.0) 3.22ms
2021-12-11 13:16:49,926 INFO 304 GET /devices (0.0.0.0) 1.41ms
2021-12-11 13:16:54,934 INFO 304 GET /devices (0.0.0.0) 1.40ms
2021-12-11 13:16:59,956 INFO 304 GET /devices (0.0.0.0) 1.46ms
2021-12-11 13:17:04,979 INFO 304 GET /devices (0.0.0.0) 1.39ms
2021-12-11 13:17:09,982 INFO 304 GET /devices (0.0.0.0) 1.41ms
2021-12-11 13:17:14,977 INFO 304 GET /devices (0.0.0.0) 1.44ms
2021-12-11 13:17:19,989 INFO 304 GET /devices (0.0.0.0) 1.41ms
2021-12-11 13:17:25,000 INFO 304 GET /devices (0.0.0.0) 3.05ms
2021-12-11 13:17:30,014 INFO 304 GET /devices (0.0.0.0) 1.75ms
2021-12-11 13:17:34,735 INFO 200 GET /static/js/esphome/c.82e709d2.js (0.0.0.0) 2.54ms
2021-12-11 13:17:34,810 INFO 200 GET /static/js/esphome/c.849528ae.js (0.0.0.0) 1.82ms
2021-12-11 13:17:34,818 INFO 200 GET /static/js/esphome/c.989b6db0.js (0.0.0.0) 1.33ms
2021-12-11 13:17:35,000 INFO 304 GET /devices (0.0.0.0) 1.67ms
2021-12-11 13:17:40,439 INFO 304 GET /devices (0.0.0.0) 3.13ms
2021-12-11 13:17:45,477 INFO 304 GET /devices (0.0.0.0) 3.61ms
2021-12-11 13:17:50,489 INFO 304 GET /devices (0.0.0.0) 3.54ms
2021-12-11 13:17:55,520 INFO 304 GET /devices (0.0.0.0) 1.46ms
2021-12-11 13:18:00,535 INFO 304 GET /devices (0.0.0.0) 2.04ms
2021-12-11 13:18:05,583 INFO 304 GET /devices (0.0.0.0) 3.16ms
2021-12-11 13:18:10,634 INFO 304 GET /devices (0.0.0.0) 3.89ms
2021-12-11 13:18:15,654 INFO 304 GET /devices (0.0.0.0) 2.36ms
2021-12-11 13:18:20,699 INFO 304 GET /devices (0.0.0.0) 1.41ms
2021-12-11 13:18:25,761 INFO 304 GET /devices (0.0.0.0) 1.40ms
2021-12-11 13:18:30,793 INFO 304 GET /devices (0.0.0.0) 1.69ms
2021-12-11 13:18:35,837 INFO 304 GET /devices (0.0.0.0) 1.41ms
2021-12-11 13:18:40,885 INFO 304 GET /devices (0.0.0.0) 1.40ms
2021-12-11 13:18:45,935 INFO 304 GET /devices (0.0.0.0) 1.53ms
2021-12-11 13:18:50,972 INFO 304 GET /devices (0.0.0.0) 1.87ms
2021-12-11 13:18:56,011 INFO 304 GET /devices (0.0.0.0) 4.13ms
2021-12-11 13:19:01,046 INFO 304 GET /devices (0.0.0.0) 1.46ms
2021-12-11 13:19:06,056 INFO 304 GET /devices (0.0.0.0) 1.52ms
2021-12-11 13:19:11,081 INFO 304 GET /devices (0.0.0.0) 4.15ms
2021-12-11 13:19:16,093 INFO 304 GET /devices (0.0.0.0) 1.38ms
2021-12-11 13:19:21,136 INFO 304 GET /devices (0.0.0.0) 3.87ms
2021-12-11 13:19:26,175 INFO 304 GET /devices (0.0.0.0) 1.46ms
2021-12-11 13:19:31,222 INFO 304 GET /devices (0.0.0.0) 3.85ms
2021-12-11 13:19:36,247 INFO 304 GET /devices (0.0.0.0) 1.98ms
2021-12-11 13:19:41,332 INFO 304 GET /devices (0.0.0.0) 2.05ms
2021-12-11 13:19:46,294 INFO 304 GET /devices (0.0.0.0) 3.30ms
2021-12-11 13:19:51,317 INFO 304 GET /devices (0.0.0.0) 3.14ms
2021-12-11 13:19:56,346 INFO 304 GET /devices (0.0.0.0) 1.39ms
2021-12-11 13:20:01,384 INFO 304 GET /devices (0.0.0.0) 1.85ms
2021-12-11 13:20:06,419 INFO 304 GET /devices (0.0.0.0) 3.51ms
2021-12-11 13:20:11,423 INFO 304 GET /devices (0.0.0.0) 1.77ms
2021-1
