Can't connect to ESPHome API - No ESPHome devices are online
Hello
i have a problem with ESPHome. after several hours the ESPHome devices are not connected. and i see this message in the logs.
how to fix this problem?
What are IP’s of your remote devices? Do you have static IP’s or you let router define IP’s? Set them to static. When using DHCP IP’s can change and you have problems.
