Cant connect to ESPHome device
One of my sonoff minis with Esphome blew a capacitor so i replaced it with another pre-flashed device, planning to flash in the original firmware of the damaged one.
So the “new” device creates a captive portal, but cant flash the firmware into it OTA because it resets the connection (tried over an android phone). My second attempt was to connect it to the wifi and try OTA from the web interface, but I can’t access the device over the web. it responds to ping, but no web interface comes up and the esphome dashboard also can’t see it…
Currently i don’t have the possibility to connect it to to an USB-TTL adaptor nor cut the power to it to reset it, so i need to resolve this somehow over the network…
What is it currently flashed with?
its a different EPHome build that is set up for a another AP that is not available at its current location
substitutions:
  esphome_name: kitchen_led
esphome:
  platform: ESP8266
  board: esp8285
wifi:
  ssid: radirpok_iot_street
  password: !secret iot_password
  domain: !secret local_domain
  ap:
    ssid: "${esphome_name}_fallback"
    password: !secret ap_password
api:
  reboot_timeout: 60min
ota:
time:
  - platform: homeassistant
captive_portal:
# Enable web server
web_server:
  port: 80
# Enable logging
logger:
# Physical button
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO0
      mode: INPUT_PULLUP
      inverted: True
    on_press:
      # Prevents unintended LED lit states.
      if:
        condition:
          - switch.is_off: logical
        then:
          - switch.turn_on: blue_led
          - switch.turn_on: logical
        else:
          - switch.turn_off: logical
  - platform: uptime
  - platform: wifi_signal
    name: "${esphome_name} WiFi Signal"
    update_interval: 60s
text_sensor:
  - platform: wifi_info
    scan_results:
      name: ESP Latest Scan Results
# Relay
output:
  - platform: gpio
    pin: GPIO12
# Logical switch to control relay and light
switch:
  - platform: output
    output: relay
    on_turn_off:
      if:
        condition:
          - switch.is_on: blue_led
        then:
          - switch.turn_off: blue_led
  - platform: gpio
    pin:
      number: GPIO13
      inverted: true
  - platform: restart
light:
  - platform: binary
    output: relay
Hmmm… You can’t cut power but wireless OTA fails at it resets connection… :see_no_evil:
I would say then boot into safe mode but you don’t have a switch or button for that in your yaml :man_shrugging:
Did you actually try to run a OTA update/install from your esphome dashboard? :arrow_double_up:
And do you have an idea what version of esphome is running on the plug and which version you got of the esphome dashboard?
after a repeated attempts somehow i was able to connect to the device via web and push an OTA update with the original config. i think the firmware version was something like 2023.7 or similar. probably the initial OTA flash from the phone failed because it was in the “new” format and I am not sure since what version its supported
