Unable to connect with HA. Ports are forwarded in modem. Login credentials are working on desktop version of HA. I’m using letsencrypt and duckdns add-on with HA at version 0.50.2. This is the screen I get in the iOS app:
Config has no errors.
I have the same problem. I’m using VPN to dial in at home and for the last days I get a lot of timeouts…
I’m still on 0.49
I’ve got it working here. When entering the settings (see screenshot in first post) only fill in URL and password. NOT DeviceID. Not sure if this tip will fix your issue @DanielGalle
