Can't connect to Hass.io install
I attempted an upgrade of my Hass.io install using the button in the Hass.io menu in the web interface.
Nothing seemed to happen and then everything stopped responding.
After a few hours of waiting I restarted the host machine with no change.
The SMB shares are still running so I guess it’s there somewhere.
This is the only log info I could find which was in /config/home-assistant.txt
I can’t make any sense of it.
2018-05-29 12:27:59 ERROR (MainThread) [homeassistant.components.tts] Error on cache init Can’t init cache dir [Errno 2] No such file or directory: ‘/home/homeassistant/.homeassistant/tts’
2018-05-29 12:27:59 ERROR (MainThread) [homeassistant.setup] Setup failed for tts: Component failed to initialize.
2018-05-29 12:28:12 WARNING (SyncWorker_4) [netdisco.ssdp] Error fetching description at 192.168.1.110
2018-05-29 12:28:12 ERROR (SyncWorker_4) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-05-29 12:28:12 WARNING (SyncWorker_4) [netdisco.ssdp] Error fetching description at http://[fe80::215:f2ff:fe37:6eea]:6544/getDeviceDesc
2018-05-29 13:28:03 ERROR (MainThread) [homeassistant.components.updater] Could not contact Home Assistant Update to check for updates
2018-05-29 21:49:49 ERROR (MainThread) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
Do I need to wipe and start over? Luckily I did a backup prior to clicking that update button.
I had similar symptoms and in my case it turned out that I ran out of disk space. My database had become very big. If you are using the default database you can delete the home-assistant_v2.db file (and lose your history data, but not your configurations).
If you are able ssh into hassio, then you can check disk space with df -h.
I was unable to so and had to do the following from an ssh to the machine running Docker which was running hassio and all addon containers:
docker ps -s
This gives you a list of containers, look for the CONTAINER ID of the one called homeassistant/qemux86-64-homeassistant or similar, just not the supervisor or addon containers.
docker exec -it <<CONTAINER ID>>> /bin/bash
This will get you in a shell inside the container with interactive mode.
df -h
Check the used disk space.
I hope that helps.
Well I checked and disk space is not an issue on my machine currently. 42 GB free still.
I ran the docker ps -s and got this:
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES SIZE
abf3877ee9f1 homeassistant/amd64-hassio-supervisor “python3 -m hassio” 11 hours ago Up 11 hours hassio_supervisor 0 B (virtual 129 MB)
d3b8f4f87b0e homeassistant/amd64-addon-configurator “/usr/bin/entry.sh…” 19 hours ago Up 19 hours 0.0.0.0:3218->3218/tcp addon_core_configurator 396 B (virtual 78.1 MB)
f77dd2e50c28 homeassistant/qemux86-64-homeassistant “python3 -m homeas…” 19 hours ago Up 19 hours homeassistant 0 B (virtual 1.19 GB)
f91c353ddced homeassistant/amd64-addon-samba “/usr/bin/entry.sh…” 19 hours ago Up 19 hours addon_core_samba 5.13 MB (virtual 49.7 MB)
e9f5ea649d4e homeassistant/amd64-addon-mosquitto “/usr/bin/entry.sh…” 19 hours ago Up 19 hours 0.0.0.0:1883->1883/tcp, 0.0 .0.0:8883->8883/tcp addon_core_mosquitto 246 B (virtual 12.8 MB)
When I did the docker exec, it still says 42 GB free.
I then noticed configurator appeared to be up on port 3218 but I was unable to connect.
Looks like it cannot get to the update site.
That may have been the case but what now?
So something new and weird for this.
My Hass.io install can back up after a host reboot, which BTW hadn’t worked the 10 times I tried before.
Hass.io reports it’s now .70 but the Configurator and the HAss.io menu items do not work, everything else seems to be functional though.
So a bit more information on this. Earlier when I connected on my cell phone I got an error message about not being able to load a panel.
Now on the phone I don’t get anything for configurator or Hass.io.
The log on the info screen have python errors in it.
Error doing job: Fatal error on SSL transport
File “/usr/lib/python3.6/asyncio/sslproto.py”, line 638, in _process_write_backlog
ssldata, offset = self._sslpipe.feed_appdata(data, offset)
AttributeError: ‘NoneType’ object has no attribute ‘feed_appdata’
I’m not sure if those icons are related
