Can't connect to hassio local after enabling cloud
Hi guys, I don’t know what I did wrong this time, suddenly after I subscribe to home assistant cloud for the first time, I can’t access the hassio.local:8123 anymore, it only says " hassio.local didn’t send any data.". But I still can access my home assistant from nabu casa.
Here’s what I did before:
  1. I have port forwarding my router to enable the remote UI, but I have deleted them all
  2. I have installed Duck DNS and successfully configure it, but I have stopped the service too
So, any of you guys ever had same problem like me ?
Do you also still have base_url set in your configuration.yaml under http:?
Hi, thanks for your reply, I don’t know if base_url matter, but I forgot to delete that before I posted this problem, and after I tried to reload the pages multiple time, tried to restart home assistant several time, and tried to unplug and plug in the raspberry pi, it suddenly works. So, I’m not sure maybe it’s because of that or not. But I will mark your answer as solution, because maybe it will help the others.
