for some reason I can no longer connect to home-assistant.io websites from my home-network. It works if I switch to mobile net on my phone or go through my works VPN (thats why I can write this…).
Everythin else on the Internet seems to work. The onlys site I have problem with is this.
I have no outgoing rules in my firewall, DNS works but something blocks my traffic.
Due to this I can’t fetch the latest updates.
Is it my ISP that is mad at you or is it anything else? What have you done to deserve this?
[core-ssh ~]$ host [community.home-assistant.io](http://community.home-assistant.io/)
[community.home-assistant.io](http://community.home-assistant.io/) has address 104.26.4.238
[community.home-assistant.io](http://community.home-assistant.io/) has address 104.26.5.238
[community.home-assistant.io](http://community.home-assistant.io/) has address 172.67.68.90
[community.home-assistant.io](http://community.home-assistant.io/) has IPv6 address 2606:4700:20::ac43:445a
[community.home-assistant.io](http://community.home-assistant.io/) has IPv6 address 2606:4700:20::681a:5ee
[community.home-assistant.io](http://community.home-assistant.io/) has IPv6 address 2606:4700:20::681a:4ee
[community.home-assistant.io](http://community.home-assistant.io/) mail is handled by 10 [mxb.mailgun.org](http://mxb.mailgun.org/).
[community.home-assistant.io](http://community.home-assistant.io/) mail is handled by 10 [mxa.mailgun.org](http://mxa.mailgun.org/).
[core-ssh ~]$
[core-ssh ~]$
[core-ssh ~]$
[core-ssh ~]$ curl -vvv [https://community.home-assistant.io](https://community.home-assistant.io/)
* Trying 172.67.68.90:443...
* Trying 2606:4700:20::ac43:445a:443...
* Immediate connect fail for 2606:4700:20::ac43:445a: Address not available
* Trying 2606:4700:20::681a:5ee:443...
* Immediate connect fail for 2606:4700:20::681a:5ee: Address not available
* Trying 2606:4700:20::681a:4ee:443...
* Immediate connect fail for 2606:4700:20::681a:4ee: Address not available
* connect to 172.67.68.90 port 443 failed: Operation timed out
* Trying 104.26.4.238:443...
* After 84413ms connect time, move on!
* connect to 104.26.4.238 port 443 failed: Operation timed out
* Trying 104.26.5.238:443...
* After 42206ms connect time, move on!
* connect to 104.26.5.238 port 443 failed: Operation timed out
* Failed to connect to [community.home-assistant.io](http://community.home-assistant.io/) port 443 after 257796 ms: Operation timed out
* Closing connection 0
curl: (28) Failed to connect to [community.home-assistant.io](http://community.home-assistant.io/) port 443 after 257796 ms: Operation timed out
[core-ssh ~]$
[core-ssh ~]$ traceroute [community.home-assistant.io](http://community.home-assistant.io/)
traceroute to [community.home-assistant.io](http://community.home-assistant.io/) (172.67.68.90), 30 hops max, 46 byte packets
1 [a0d7b954-nodered.local.hass.io](http://a0d7b954-nodered.local.hass.io/) (172.30.32.1) 0.028 ms 0.030 ms 0.022 ms
2 network (192.168.1.1) 0.607 ms 0.582 ms 0.532 ms
3 xxx.xxx.32.1 (xxx.xxx.32.1) 5.517 ms 5.652 ms 5.560 ms
4 xxx.xxx.0.252 (xxx.xxx.0.252) 6.984 ms 9.827 ms 8.636 ms
5 [pni-bahnhof-a3.bahnhof.net](http://pni-bahnhof-a3.bahnhof.net/) (46.59.118.215) 9.377 ms 6.826 ms 6.296 ms
6 * * *
7 * * *
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
