Did the upgrade to High Sierra on my MacBook Pro and now I can’t connect to Hass.io’s SMB share. It still works (and has worked flawlessly for months) from my iMac with MacOS Sierra.
When making the attempt via the Connect to Server dialog in Finder (to smb://hassio.local), it tries for about 3 seconds and then responds with:
There was a problem connecting to the server “hassio.local”. Check the server name or IP address, and then try again. If you continue to have problems, contact your system administrator.
It never asks for my credentials, and I verified there aren’t any cached in Keychain. The MacBook has no problem resolving “hassio.local” to the correct local IP address, but I tried mounting directly with the IP anyway and got the same result.
I’ve been digging around for clues on SMB issues with High Sierra but haven’t gotten anywhere. Is anyone experiencing this issue or is it just me?
