I just tried to connect my inverter with an usb modbus dongle - no success.
Can’t find the usb converter in my hardware.
I tried to establish a connection with the Protoss PE11 - I configured the device as demanded. Can’t find the modbus Server - no network connection to the Protoss.
What is wrong with my HA installation? I a m new to HA so the problem might be me.
Do I need a code prior installation?
Protoss PE 11 ist connected properly to the network/ switch and to the A/B RS485 Arts directly on the inverter.
SDongle is attached to the inverter and connected via lan to the switch/router.
web port: 502
local port: 8899
fixed ip: 192.168.0.99
tcp server
uart
huawei_solar ist in the custom_components.
do i need to paste some code into the configuration.yaml?
tried different id, started several times - I have no idea.
