Can't connect to wifi - lwIP error -16
Suddently, my Esp stoppet connecting to my wifi network. I can see this log:
[15:28:53][I][wifi:248]: WiFi Connecting to 'wifi'...
[15:28:53][W][wifi_esp8266:212]: wifi_apply_hostname_(espco): lwIP error -16 on interface st (index 0)
Can anyone help me? I already tried to connect with another ESP and didn’t work. I already have 7 more Esp’s connected. I tried to connect new devices to my network and all of them worked. This is my xaml file:
esphome:
  platform: ESP8266
  board: esp01_1m
wifi:
  ssid: "wifi"
  password: "wifipass"
#  ap:
#    ssid: "Esp Compressor Fallback Hotspot"
#    password: "smDfhO4n25pl"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
#api:
ota:
output:
  - platform: gpio
    pin: 12  #D6
switch:
  - platform: output
    name: " ESP Compressor ON/OFF"
    output: 'compressor_onoff_out'
binary_sensor:
  - platform: gpio
    pin:
      number: 0 #D2
      inverted: true
      mode: INPUT_PULLUP
  - platform: gpio
    pin:
      number: 5 #D1
      inverted: true
      mode: INPUT_PULLUP
Thanks in advance
same problem here:
[I][wifi:257]: WiFi Connecting to 'myWifi'...
[W][wifi_esp8266:212]: wifi_apply_hostname_(ventilation-controller): lwIP error -16 on interface st (index 0)
[W][wifi:549]: Error while connecting to network.
Interesting enough this only happens if I use the mqtt client component.
If i remove those two lines at the end of the yaml, everything works as expected.
Also interesting @amcjoao: We’re both on a 1 MiB ESP8266.
My yaml file:
esphome:
esp8266:
  board: esp8285
api:
  encryption:
    key: !secret api_key
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "ventilation-controller"
captive_portal:
logger:
ota:
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO0
      mode:
        input: true
        pullup: true
      inverted: true
    on_press:
      - switch.toggle: relay
switch:
  - platform: gpio
    pin: GPIO12
status_led:
  pin:
    number: GPIO13
    inverted: yes
dallas:
  - pin: GPIO14
  - platform: dallas
    address: 0xb90316b5a610ff28
    name: "Zuluft Lüftungsanlage"
  - platform: dallas
    address: 0xb50316b5ade8ff28
  - platform: dallas
    address: 0xe70416c168deff28
    name: "Abluft Lüftungsanlage"
  - platform: dallas
    address: 0xb10316b5b9fbff28
    name: "Sole Rücklauf"
mqtt:
  broker: 192.168.1.10
I have this exact error after upgrading esphome to the latest version on my SonOff Basic.
Any news about this?
After updating a few esp8266, I now have the same issue: they keep looping on a lwIP error -16 on interface st (index 0) error. I have 5 of them with the same problem. The only one that still works hasn’t been updated.
Having the same issue. Anyone find a solution? At times I can even see my devices as connected on the router but the devices give this error.
Too many people asking similar questions. I will only address the OP.
lwIP uses memory pools for network packet and buffer management. Error -16 could potentially be related to memory allocation issues.
You don’t need captive_portal:. Delete this line- it will save memory.
You don’t say which ESP development board you are using, but I have several ESP8266-01, 1MB boards all over my house and I’ve never seen this error. However, I have seen one instance where two ESP devices had the same MAC address. One was a Sonoff Basic and the other was an ESP8266-01. Needless to say the ESP-01 is trash now.
Of course but many people have legacy device deployed and an update is “breaking” them.
