Not sure what I am missing, here. I followed the instructions and added the following to my configuration.yaml:
vera:
vera_controller_url: http://10.0.0.112:3480/
Here is the error from the log:
Log Details (ERROR)
Wed Oct 23 2019 00:33:10 GMT-0700 (Mountain Standard Time)
Error communicating with Vera API
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 157, in _new_conn
(self._dns_host, self.port), self.timeout, **extra_kw
File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 84, in create_connection
raise err
File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 74, in create_connection
sock.connect(sa)
socket.timeout: timed out
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 672, in urlopen
chunked=chunked,
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 387, in _make_request
conn.request(method, url, **httplib_request_kw)
File "/usr/local/lib/python3.7/http/client.py", line 1244, in request
self._send_request(method, url, body, headers, encode_chunked)
File "/usr/local/lib/python3.7/http/client.py", line 1290, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.7/http/client.py", line 1239, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.7/http/client.py", line 1026, in _send_output
self.send(msg)
File "/usr/local/lib/python3.7/http/client.py", line 966, in send
self.connect()
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 184, in connect
conn = self._new_conn()
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 164, in _new_conn
% (self.host, self.timeout),
urllib3.exceptions.ConnectTimeoutError: (<urllib3.connection.HTTPConnection object at 0x729e4970>, 'Connection to 10.0.0.112 timed out. (connect timeout=30)')
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 449, in send
timeout=timeout
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 720, in urlopen
method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
File "/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py", line 436, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='10.0.0.112', port=3480): Max retries exceeded with url: //data_request?id=sdata (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x729e4970>, 'Connection to 10.0.0.112 timed out. (connect timeout=30)'))
File "/usr/src/homeassistant/homeassistant/components/vera/__init__.py", line 88, in setup
all_devices = controller.get_devices()
File "/usr/local/lib/python3.7/site-packages/pyvera/__init__.py", line 193, in get_devices
self.get_simple_devices_info()
File "/usr/local/lib/python3.7/site-packages/pyvera/__init__.py", line 113, in get_simple_devices_info
j = self.data_request({'id': 'sdata'}).json()
File "/usr/local/lib/python3.7/site-packages/pyvera/__init__.py", line 109, in data_request
return requests.get(request_url, timeout=timeout, params=payload)
File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 75, in get
return request('get', url, params=params, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 60, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 533, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 646, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 504, in send
raise ConnectTimeout(e, request=request)
requests.exceptions.ConnectTimeout: HTTPConnectionPool(host='10.0.0.112', port=3480): Max retries exceeded with url: //data_request?id=sdata (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x729e4970>, 'Connection to 10.0.0.112 timed out. (connect timeout=30)'))
I’ve also tried port 80, and adding ‘/cmh’ to the URL. I am able to get to the vera dashboard at http://10.0.0.112/cmh (port 80).
Is this integration broken?
Keith
