Hi all,
About a year ago I abandoned my home assistant smart home setup cause I didn’t have the time anymore but nog I want to re-install everything but I can’t get my Xiaomi Gateway (v3) to work as it did before.
Home assistant does (auto)recognize my device as a Xiaomi Miio but the Miio integration doesn’t support my Xiamo Door sensor, motion sensor and switch.
I remember that in my previous setup the gateway was working with the Aqara integration.
When I try to get the Aqara integration working with my device I can’t get it to work. It doesn’t see my gateway.
When I go back to the auto discovered Miio integration it does connect with my gateway.
Why can’t I use the Aqara integration anymore? Does anybody have a clue?
Thanks in advance.
I’m running home assistant in a virtual environment on a Raspberry Pi 3
Kind regards,
Mark
