Hi everyone,
I have my ConBee II currently configured via deCONZ but I would like to try ZHA for simplicity. I have installed Home Assistant in a Docker container in Ubuntu, and have tried to add the integration via the GUI, where I get the error that /dev/ttyACM0 can’t be found, and also by modifying the configuration.yaml file like this:
zha:
usb_path: /dev/ttyACM0
radio_type: deconz
database_path: /config/zigbee.db
In this case, the error I can see in my logs looks like this:
Error setting up entry /dev/ttyACM0 for zha
File "/usr/local/lib/python3.7/site-packages/serial/serialposix.py", line 244, in open
self.fd = os.open(self.portstr, os.O_RDWR | os.O_NOCTTY | os.O_NONBLOCK)
FileNotFoundError: [Errno 2] No such file or directory: '/dev/ttyACM0'
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 192, in async_setup
hass, self
File "/usr/src/homeassistant/homeassistant/components/zha/__init__.py", line 107, in async_setup_entry
await zha_gateway.async_initialize()
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 114, in async_initialize
await radio.connect(usb_path, baudrate)
File "/usr/local/lib/python3.7/site-packages/zigpy_deconz/api.py", line 198, in connect
self._uart = await uart.connect(device, DECONZ_BAUDRATE, self)
File "/usr/local/lib/python3.7/site-packages/zigpy_deconz/uart.py", line 120, in connect
xonxoff=False,
File "/usr/local/lib/python3.7/asyncio/coroutines.py", line 120, in coro
res = func(*args, **kw)
File "/usr/local/lib/python3.7/site-packages/serial_asyncio/__init__.py", line 410, in create_serial_connection
ser = serial.serial_for_url(*args, **kwargs)
File "/usr/local/lib/python3.7/site-packages/serial/__init__.py", line 88, in serial_for_url
instance.open()
File "/usr/local/lib/python3.7/site-packages/serial/serialposix.py", line 247, in open
raise SerialException(msg.errno, "could not open port {}: {}".format(self._port, msg))
serial.serialutil.SerialException: [Errno 2] could not open port /dev/ttyACM0: [Errno 2] No such file or directory: '/dev/ttyACM0'
I have verified that the device is listed under /dev, have changed its permissions and as I said above, it does work with deCONZ. I have also removed modemmanager to avoid interferences with it. The firmware is the latest one.
I’ve run out of ideas and I don’t know what I can do next. Any suggestions? Thanks!
