Hi, I have a chandelier with two yeelight bulbs. They’re grouped together for a simple wall switch to toggle it on/off.
There’s a second control - a Xiaomi button that’s set up for warm (single click), cool (double click) and turn off (hold).
Problem: I want to be able to control a single bulb (for super dim lighting) with triple click BUT it always triggers the second bulb as well. How to avoid this? I set the automation to specifically switch off the other bulb but it turns on anyway. The triple click is triggered correctly according to zigbee2mqtt. It is not limited to automations - when I toggle a single bulb manually, the other one toggles as well. I CAN control the bulbs independently via the Yeelight app so this is a HA problem.
