Can't control thermostat with Google Home
I have exposed a thermostat to Google Assistant/Home and it shows up with the right status. However, when I change settings, it starts blinking and doesn’t update to Home Assistant.
It works the other way around: if I change the setting in Home Assistant and reload/reopen the thermostat in Google, I see the new settings.
I have no clue what I could do to fix this. Do you guys have any idea?
All other stuff like lamps and switches work, btw.
I am experiencing the same situation. Everything works from GH to HA but my Z-wave thermostats. Can’t change mode or setpoints. Not an interface concern as I prefer HA, but I would like to tell Google to change the temperature and that isn’t working. I have both radio thermostat C101s and and Honeywell Z-wave thermostats.
Edit: I just upgraded to 23.6.1 and the updated Z-Wave JS has fixed the problem I was having. GH can now update the HA Z-Wave thermostat. Thanks!!
