Thanks for answer…
Here my setup: Dell Optiplex 3090 i5 with Proxmox.
On Proxmox the hassio.
On the computer a USB extension cable 3 meters with a Conbee || stick with latest firmware.
Zigbee2MQTT channel 11 and all my WiFi AP;s on channel 1, 6 and 9 and now neigbors.
But still problems i have restart my system many times… updates everything, but i looks like the refresh time is not oke in Zigbee/MQTT to HomeAssitant… here logs of my zigbee2mqtt:
Zigbee2MQTT:error 2022-06-28 22:05:50: Publish ‘set’ ‘state’ to ‘Lampen woonkamer boekenkast’ failed: ‘Error: Command 0xa4c138f708f9d052/1 genOnOff.on({}, {“sendWhen”:“immediate”,“timeout”:10000,“disableResponse”:false,“disableRecovery”:false,“disableDefaultResponse”:false,“direction”:0,“srcEndpoint”:null,“reservedBits”:0,“manufacturerCode”:null,“transactionSequenceNumber”:null,“writeUndiv”:false}) failed (no response received)’
Zigbee2MQTT:error 2022-06-28 22:54:54: Publish ‘set’ ‘state’ to ‘Led strip TV’ failed: ‘Error: Command 0xa4c138efd4094e94/1 genOnOff.off({}, {“sendWhen”:“immediate”,“timeout”:10000,“disableResponse”:false,“disableRecovery”:false,“disableDefaultResponse”:false,“direction”:0,“srcEndpoint”:null,“reservedBits”:0,“manufacturerCode”:null,“transactionSequenceNumber”:null,“writeUndiv”:false}) failed (no response received)’
Zigbee2MQTT:error 2022-06-28 22:55:14: Publish ‘set’ ‘state’ to ‘Led strip TV’ failed: ‘Error: Command 0xa4c138efd4094e94/1 genOnOff.on({}, {“sendWhen”:“immediate”,“timeout”:10000,“disableResponse”:false,“disableRecovery”:false,“disableDefaultResponse”:false,“direction”:0,“srcEndpoint”:null,“reservedBits”:0,“manufacturerCode”:null,“transactionSequenceNumber”:null,“writeUndiv”:false}) failed (no response received)’
Zigbee2MQTT:error 2022-06-28 22:55:54: Publish ‘set’ ‘state’ to ‘Nachtlampje Robbert’ failed: ‘Error: Command 0xa4c1380a214afbe7/1 genOnOff.on({}, {“sendWhen”:“immediate”,“timeout”:10000,“disableResponse”:false,“disableRecovery”:false,“disableDefaultResponse”:false,“direction”:0,“srcEndpoint”:null,“reservedBits”:0,“manufacturerCode”:null,“transactionSequenceNumber”:null,“writeUndiv”:false}) failed (no response received)’
Zigbee2MQTT:error 2022-06-28 22:55:54: Publish ‘set’ ‘state’ to ‘Nachtlampje Nanette’ failed: ‘Error: Command 0xa4c1384ac2ec0d37/1 genOnOff.on({}, {“sendWhen”:“immediate”,“timeout”:10000,“disableResponse”:false,“disableRecovery”:false,“disableDefaultResponse”:false,“direction”:0,“srcEndpoint”:null,“reservedBits”:0,“manufacturerCode”:null,“transactionSequenceNumber”:null,“writeUndiv”:false}) failed (no response received)’
Zigbee2MQTT:error 2022-06-28 22:55:54: Publish ‘set’ ‘state’ to ‘Lamp woonkamer links naast tv’ failed: ‘Error: Command 0xa4c138f4ef80d753/1 genOnOff.off({}, {“sendWhen”:“immediate”,“timeout”:10000,“disableResponse”:false,“disableRecovery”:false,“disableDefaultResponse”:false,“direction”:0,“srcEndpoint”:null,“reservedBits”:0,“manufacturerCode”:null,“transactionSequenceNumber”:null,“writeUndiv”:false}) failed (no response received)’
Zigbee2MQTT:error 2022-06-28 22:55:54: Publish ‘set’ ‘state’ to ‘Lampen woonkamer boekenkast’ failed: ‘Error: Command 0xa4c138f708f9d052/1 genOnOff.off({}, {“sendWhen”:“immediate”,“timeout”:10000,“disableResponse”:false,“disableRecovery”:false,“disableDefaultResponse”:false,“direction”:0,“srcEndpoint”:null,“reservedBits”:0,“manufacturerCode”:null,“transactionSequenceNumber”:null,“writeUndiv”:false}) failed (no response received)’
Zigbee2MQTT:error 2022-06-29 09:00:46: Publish ‘set’ ‘state’ to ‘Lampen woonkamer boekenkast’ failed: ‘Error: Command 0xa4c138f708f9d052/1 genOnOff.off({}, {“sendWhen”:“immediate”,“timeout”:10000,“disableResponse”:false,“disableRecovery”:false,“disableDefaultResponse”:false,“direction”:0,“srcEndpoint”:null,“reservedBits”:0,“manufacturerCode”:null,“transactionSequenceNumber”:null,“writeUndiv”:false}) failed (no response received)’
Zigbee2MQTT:error 2022-06-29 10:08:01: Publish ‘set’ ‘state’ to ‘Lampen woonkamer boekenkast’ failed: ‘Error: Command 0xa4c138f708f9d052/1 genOnOff.off({}, {“sendWhen”:“immediate”,“timeout”:10000,“disableResponse”:false,“disableRecovery”:false,“disableDefaultResponse”:false,“direction”:0,“srcEndpoint”:null,“reservedBits”:0,“manufacturerCode”:null,“transactionSequenceNumber”:null,“writeUndiv”:false}) failed (no response received)’
Anybody options to test?
