Cant create id to check a toggle button for deep sleep in home assistant for ota update on nodemcu
i cant create id in esphome configuration to stop deep sleep in nodemcu based on a toggle button that is present on home assistant
Error
Mapping values are not allowed for " id: prevent_deep_sleep "
Based on this
esphome:
  platform: ESP8266
  board: nodemcuv2
  on_boot:
    then:
      – script.execute: consider_deep_sleep
wifi:
  ssid: "XXXXXX"
  password: "XXXXXX"
  ap:
    ssid: " livingroom Fallback Hotspot"
    password: "XXXXXXX"
captive_portal:
  - platform: ultrasonic
    trigger_pin: D1
    echo_pin: D2
logger:
# Enable Home Assistant API
api:
ota:
deep_sleep:
  sleep_duration: 30s
# Will only pick up a value if this device is configured in Home Assistant > Integrations
# If the device isn't configured, or Home Assistant is offline, it'll default to false
binary_sensor:
  – platform: homeassistant
    entity_id: input_boolean.prevent_deep_sleep
script:
  – id: consider_deep_sleep
    mode: queued
    then:
      – delay: 10s
      – if:
          condition:
            binary_sensor.is_on: prevent_deep_sleep
          then:
            – logger.log: 'Skipping sleep, per prevent_deep_sleep'
          else:
            – deep_sleep.enter: deep_sleep_control
You need to remove the api: and add the mqtt: information.
mqtt:
  broker: 192.168.xxx.xxx
  username: !secret mqtt_username
  password: !secret mqtt_password
  birth_message:
    topic: battery_voltage/topic
    payload: online
  will_message:
    payload: offline
  on_message:
    - topic: deep_sleep/ota_mode
      payload: 'ON'
      then:
        - deep_sleep.prevent: battery_deep_sleep
      payload: 'OFF'
      then:
        - deep_sleep.enter: battery_deep_sleep
can you please share the entire code and i want to use esphome api rather then using mqtt, anything would work ! thanks
Check this post that has all the information you need.
esphome:
  platform: ESP8266
  board: esp12e
  on_boot:
    then:
      - script.execute: consider_deep_sleep
wifi:
  ssid: !secret wifi_ssid
  fast_connect: true
  power_save_mode: light
  ap:
    ssid: "pondsensor Fallback Hotspot"
    password: !secret fall
captive_portal:
# Enable logging
logger:
api:
  password: !secret api
ota:
  password: !secret ota
dallas:
  - pin: GPIO4
    update_interval: 2s
  - platform: dht
    pin: GPIO5
    temperature:
      filters:
        - lambda: return x * (9.0/5.0) + 32.0;
      unit_of_measurement: "Β°F"
    humidity:
    update_interval: 5s
  - platform: dallas
    address: 0x4001193A17927B28
    name: "Pond temperature"
    filters:
  - platform: adc
    pin: A0
    name: "A0 Voltage x 4.2"
    update_interval: 5s
    accuracy_decimals: 4
    filters:
      - sliding_window_moving_average:
          window_size: 30
          send_every: 5
      - multiply: 4.2
    name: "Pond Sensor battery_level"
    unit_of_measurement: '%'
    update_interval: 5s
    accuracy_decimals: 2
    lambda: |-
      return ((id(LIION).state-3) /1.1 * 100.00);
    name: "Pond Sensor battery_level_curve"
    update_interval: 5s
    lambda: |-
      return (id(LIION).state);
    filters:
      - calibrate_polynomial:
          degree: 2
          datapoints:
          # Map 0.0 (from sensor) to 0.0 (true value)
            - 3.25 -> 0.0
            - 3.4 -> 10
            - 3.55 -> 50
            - 4.1 -> 100
            - 4.3 -> 100
## Deep Sleep
deep_sleep:
  sleep_duration: 5min
binary_sensor:
  - platform: homeassistant
    entity_id: input_boolean.ICU
script:
  - id: consider_deep_sleep
    mode: queued
    then:
      - delay: 10s
      - if:
          condition:
            binary_sensor.is_off: ICU
          then:
            - logger.log: 'Not connected to HomeAssisstant. Please setup in HA to enable deepsleep'
          else:
            - if:
                condition:
                then:
                  - logger.log: 'Skipping sleep, per prevent_deep_sleep'
                else:
                  - logger.log: 'Feeling Sleepy'
                  - deep_sleep.enter: deep_sleep_control
Mttq will be the end goal, but here is my stop-gap with the api. Not pretty could be better but works for me.
Thanks for posting this solution. Your sleep function works excellent on my ESP Cam. :slight_smile: I was looking for something working like this.
I used the config above for a device on my mailbox that runs on a single 18650 battery which is on my front yard and sometimes it takes more than a minute to connect with Home Assistant.
I think I have improved it a little bit to still enter sleep mode if it’s not able to connect with HA after a few attempts. (for example if the server is down or forgot to enable ICU)
My config sets variable sleep duration based on time which is retrieved from HA. The sleep duration is 1h if it wakes up before 7:00AM, 15min before 4:00PM and 30min after 4:00PM.
Feel free to edit/improve it for your needs.
globals:
  - id: connectAttempts
    type: int
    restore_value: no
    initial_value: '0'
deep_sleep:
  sleep_duration: 15min
binary_sensor:
    entity_id: input_boolean.icu
time:
script:
    mode: queued
    then:
      - delay: 10s
      - if:
          condition:
          then:
            - logger.log: 'Not connected to HomeAssisstant. Setup ICU and enable in HA to enable deepsleep'
            - if:
              # if ICU is off or not connected to HA, try 10 times (10x10sec) to connect or else enter sleep mode
                condition:
                  - lambda: |-
                      if (id(connectAttempts) < 9) {
                        id(connectAttempts) += 1;
                        ESP_LOGD("customSleep", "Connection Attempts: %d", id(connectAttempts));
                        return false;
                      else {
                        id(connectAttempts) = 0;
                        id(deep_sleep_control).set_sleep_duration(900000);
                        ESP_LOGD("customSleep", "Set Sleep Duration: %d min", 900000/60000);
                        return true;
                then:
                  - logger.log: 'Entering Deep Sleep after failed attempts to connect with HA and read ICU'
                  - delay: 500ms
                else:
                  - logger.log: 'Try again to connect with HA'
          else:
            - if:
              # if prevent is off enter sleep: 15min if time is invalid, 1h before 7:00, 15min before 16:00, 30min after 16:00
                condition:
                then:
                  - logger.log: 'Skipping sleep. Disable "Prevent Deep Sleep" in HA to enable sleep'
                else:
                  - lambda: |-
                      auto time = id(ha_time).now();
                      if (time.is_valid()){
                        if (time.hour < 7 ){
                          id(deep_sleep_control).set_sleep_duration(3600000);
                          ESP_LOGD("customSleep", "Set Sleep Duration: %d min", 3600000/60000);
                        else if (time.hour < 16 ){
                        else{
                          id(deep_sleep_control).set_sleep_duration(1800000);
                          ESP_LOGD("customSleep", "Set Sleep Duration: %d min", 1800000/60000);
                      else{
                        ESP_LOGD("customSleep", "Wrong Time - Set Sleep Duration: %d min", 900000/60000);
                  - logger.log: 'Entering Deep Sleep'
                  - delay: 500ms
Screenshot 2021-08-13 at 17.09.46
