in HA 2021.12.2 (and also with the previous version) I am unable to create a new automation using the web ui. From create automation I select either to create a new empty one or select one of two templates. Behavior is identical.
The form for the automation appears for a blink of an eye and disappears. I am still a the list of automations.
There are no log messages generated.
Is the position of the include block in the configuration.yaml important? I have it
Running 2021.12.3… got the same thing now. Nothing in the log file. Found this thread.
In FireFox:
[+ Add Automation] > Start with an empty automation > just redraws the list of automations.
Tried clear cache/data/cookies, tried force refresh, didn’t help.
Tried Chromium Browser which I have no used in a while, had an older version of the frontend cached and it was able to add an automation no problem. I ignored the “A new version of the frontend is available” message. I then reloaded the frontend, and was still able to create an automation in Chromium.
Tried in Firefox again, still not working, but can use it to edit the automation I created in Chromium. Just can’t create a new one.
Iam having same issue, can’t add any automations anymore
I think it has something to do with me edditing the blueprints and repositioning them is that possible ?
