Fill_Hk
(Fill Hk)
October 20, 2022, 3:27am
1
I have HA’s latest version and today decides to test tags/
So I have created a tag (no issues)
Then I click on robot and select all conditions etc - everything is ok
The issue is:
When I click SAVE - I see a popup with RENAME options and to buttons: cancel or rename.
As a result, I CAN’T save automation for the TAG
Does it save of you click on Rename?
Fill_Hk
(Fill Hk)
October 20, 2022, 4:15am
3
Nope,
You can try it, you don’t even need to make real automation.
Yep. Same for me.
Could you put this on GitHub as an issue?
Fill_Hk
(Fill Hk)
October 21, 2022, 4:16pm
5
No solution yet, have reported this issue…
DAE51D
(Daevid Vincent)
March 20, 2024, 12:54am
6
I JUST started to play with this NFC tag stuff today and hit the exact same confusing situation. This is a poor design workflow apparently… I updated the GitHub ticket here. Others should do the same to get some traction to fix this properly.
opened 12:39PM - 10 Nov 23 UTC
closed 11:02AM - 17 Nov 23 UTC
### Checklist
- [X] I have updated to the latest available Home Assistant versi… on.
- [X] I have cleared the cache of my browser.
- [X] I have tried a different browser to see if it is related to my browser.
### Describe the issue you are experiencing
After adding a tag and then selecting the automation setting, creating an automation and hitting save does not save the automation but instead pops up a save dialog box.
If you rename the automation or hit cancel, the automation is not saved.
As a result, leaving the tag page loses the automation.
Issue occurs on multiple browsers and computers.
Same as Issue #14139 but that was a different version.
### Describe the behavior you expected
Creating an automation for a tag does not get saved when hitting the save button.
### Steps to reproduce the issue
1. Scan a tag
2. Select automation with tag.
3. Add a device and action
4. Hit save
5. Rename prompt appears. Hit cancel or choose a new name
6. Hit the back arrow to navigate to the tags page
7. Select automation with tag - page has been wiped back to normal
### What version of Home Assistant Core has the issue?
Core 2023.11.1 Supervisor 2023.11.0 Operating System 11.1 Frontend 20231030.1
### What was the last working version of Home Assistant Core?
_No response_
### In which browser are you experiencing the issue with?
Edge Dev 120.0.2186.2
### Which operating system are you using to run this browser?
Windows 11 23H2
### State of relevant entities
_No response_
### Problem-relevant frontend configuration
_No response_
### Javascript errors shown in your browser console/inspector
_No response_
### Additional information
_No response_
