Can't delete an entity
I had a light running Tasmota, and I flashed it with espHome. Works fine.
The Tasmota entity was created in configuration.yaml, I deleted it and cleared the retained flag for the entity using mqtt explorer, then rebooted.
The MQTT entity did in fact disappear and was not rediscovered.
But now I am totally mysterified where this entity comes from:
Belkin??? I have no Belkin devices on my system, so where does this entity come from?
Of course clicking on the device brings up the
A grep search shows it only in core.device.registry, can that section be safely deleted?
    "version": 1,
    "minor_version": 3,
    "key": "core.device_registry",
    "data": {
        "devices": [
              "config_entries": [
                  "69e20d87033811ebbc00c57f2db736c7"
              "connections": [
                      "upnp",
                      "uuid:Socket-1_0-201612K008674B8"
              "identifiers": [
                      "wemo",
                      "201612K008674B8"
              "manufacturer": "Belkin",
              "model": "Socket",
              "name": "Dining Room Light",
              "sw_version": "",
              "hw_version": null,
              "entry_type": null,
              "id": "19809392057e23e58aa5cb33fd450bb1",
              "via_device_id": null,
              "area_id": null,
              "name_by_user": null,
              "disabled_by": null,
              "configuration_url": null
I was able to disable the device in ‘device information’, but it’s still registered.
I tried to remove the annoying _2 from the entity:
Any ideas?
Remove the integration “Belkin WeMo”
The corelated entities should disappear.
Then you will be able to rename the entity.
And I said, wait! I don’t have any WeMo devices… But somehow, there it was. (I didn’t see it in my page of 30 integrations).
