I tried installing Frigate but couldn’t get it working so decided to put it aside and maybe try again down the road. I uninstalled the integration but noticed the Frigate folder was still in /config/custom_components. I get warnings about finding the custom integration. I can’t delete the */config/custom_components/frigate folder because the “directory isn’t empty”.
I read that removing the repository from the addon store would do it but it didn’t. If I want to attempt another install at some point I don’t want problems with left over files and folders.
Should I just leave it or is there a way to delete it?
Can you delete files from directory before you delete dir?
Anyway you can probably rename dir to something like my_dir.org so new installation should create new dir with new files in it.
