Hi
Im trying to delete some obsolete group helper, its marked in red in UI and in log HA complains about it in log every time
Logger: homeassistant.helpers.service
Source: helpers/service.py:301
First occurred: July 27, 2024 at 17:15:00 (232 occurrences)
Last logged: 12:45:00
Referenced entities automation.floor_1_lights_on_motion_1 are missing or not currently available
there are no entities inside it
there is no delete button for it…
how can i delete it?
no
i created it with helper some time ago
then i removed the entities but i cant delete the group now
anyway, which yaml file contains this? i could not find it
I just tested and I could not delete the group if it had no entities in it.
As soon as I added an entity, then I could delete the group.
This sounds a bit like an unintended situation.
I tried adding entity, still wont get delete button
I suspect its something garbage in HA DB that thinks this entity is somehow partly alive that allows me to edit but not delete it
Look for the group entity in the entities table, not the helpers table. You should be able to delete it from there.
For some reason I don’t understand the helpers table jumps straight to options flow for entities which are disabled/unavailable instead of showing their entity registry settings (where the delete button lives).
