I’m trying to disable debug logging for an integration by clicking the 3-dot menu → “disable debug logging”. However, it instead just downloads the log instead of disabling debug logging. How can I just disable debug logging?
Edit: I ended up upgrading Hass to the latest version and restarted. I guess that fixed it.
Same issue here, also had enabled debug for integration, disabled it and downloaded the log, but the log file home-assistant.log gets filled like crazy with all sorts of debug logs.
Glad I found this. Me too – not sure why debug was turned on in the config file. Do I need to reboot to get the change to configuration.yaml to take effect? (Clearly, if I don’t know the answer to that, I probably shouldn’t be editing configuration.yaml. )
EDIT: I though just doing a lightweight “Quick reload” would do it, since it purports to apply yaml config changes, but that didn’t do it. A full hardware reboot did the trick. Perhaps there’s a middle ground.
