Can't disable discovery Upnp
What am I doing wrong?
# ----------All the Integrations --------------
tts:
  - platform: google_translate
discovery:
  ignore:
    - upnp
    - igd
gives me the error
Invalid config for [discovery]: value is not allowed @ data[‘discovery’][‘ignore’][0].
  • Got ‘upnp’ value is not allowed @ data[‘discovery’][‘ignore’][1].
  • Got ‘igd’. (See /config/configuration.yaml, line 21).
I tried both because of forum threads recommending so but I can’t seem to get it in there. Using hassio . I try to “ignore” from the front end but it keeps coming back and piling up in “view ignored integrations” - I had 5 “ingored” values of the same UPNP
? Thanks!
remove the - igd line
tts:
discovery:
  ignore:
    - upnp
I used to use ignore on UPNP and IGD but seems they have gone from the allowed ignore list and threw up errors:
Sadly, that results in the same error. I’m now updating system and versions… should have done that before. Let’s see…
That was dependent on you running the latest version…It was a breaking change to the way upnp works.
I think you can remove it completly from your config and add it as an integration now.
You’re right. That seems to have done it. It’s not showing again. Have a nice day.
I have the opposite issue, I want to discover my upnp. I declined it initially however now I cannot get the upnp to work now… Thoughts?
