I have been using an Athom Smart Plug v2 for a while now. I wanted to configure a second one just now and ran into some issues with it. Long story short, I need to reflash it and need a .bin file to do so.
I tried to pull it from my working plug, but I get the following error:
INFO Reading configuration /root/config/schuur-opladers.yaml...
INFO Detected timezone 'Etc/UTC'
Failed config
button.factory_reset: [source /root/config/.esphome/packages/43f53298/athom-smart-plug-v2.yaml:108]
Platform not found: 'button.factory_reset'.
platform: factory_reset
name: Restart with Factory Default Settings
ESPHome seems to check with the most recent package on Github which has changed compared to the pre-flashed version the plug came with I guess? I dont know how to solve this issue though. I also cant rename the plug anymore since it will throw the same error.
