Can't download OS Agent
Hello!
I can’t download OS Agent with wget althought I can download the file in my browser.
I’m using a fresh Ubuntu Server installation.
wget https://github.com/home-assistant/os-agent/releases/download/1.2.2/os-agent_1.2.2_linux_x86_64.deb
I managed to download Supervised just fine
wget https://github.com/home-assistant/supervised-installer/releases/latest/download/homeassistant-supervised.deb
What seems to be the issue?
Thanks in advance!
You know you will end with an unsupported installation ? Supervised is not supported on Ubuntu, only Debian 11. If you downloaded with browser, just use SSH to copy it over.
You are right. I was using a outdated tutorial.
Now everything is working as intended with Debian 11.
Thanks !
:+1: Good so.
