Leon333
September 17, 2019, 4:04pm
1
I am trying to edit the configuration.yaml, but I can not even see it.
In the past I have used HASS.IO on a raspberry and it had a nice configuration possibility via a browser.
This time I’m using a mini server that runs a VM with dietpi.
After the home assistant ist freshly installed - i see no option to change it to my needs.
I even cant see a Add-On Store or anything and feeling lost.
I hope you guys can help me out (because always editing via terminal is not a long term option).
Thanks a lot!
silvrr
September 17, 2019, 4:14pm
2
You didn’t install Hassio therefore you don’t have addon’s. The tool you were likely using was the configurator add-on.
# Home Assistant Add-on: File editor
Browser-based configuration file editor for Home Assistant.
![Supports aarch64 Architecture][aarch64-shield] ![Supports amd64 Architecture][amd64-shield] ![Supports armhf Architecture][armhf-shield] ![Supports armv7 Architecture][armv7-shield] ![Supports i386 Architecture][i386-shield]
![Configurator in the Home Assistant Frontend][screenshot]
## About
The File editor, formerly known as Configurator, is a small web-app (you access it via web browser) that provides a
filesystem-browser and text-editor to modify files on the machine the File editor is
running on.
It is powered by Ace editor, which supports syntax highlighting for various
code/markup languages. YAML files (the default language for Home Assistant
configuration files) will be automatically checked for syntax errors while editing.
## Features
This file has been truncated. show original
You installed ontop of linux in a virtual environment.
If you want addons and Hassio features you need to install hassio.
Leon333
September 17, 2019, 4:56pm
3
Thanks silvrr for your reply.
Is there a way to get the yaml editor into webinterface without hassio?
I remember that hassio also had its drawbacks (like problems on configuring snips with custom settings etc…).
gongora
(Marcel R Gongora)
September 14, 2020, 7:05pm
5
Not sure if you are still interested in this but for future references: https://github.com/danielperna84/hass-configurator/wiki/Installation
