Cant figure out how to config automations.yaml
Hi!
Im new here. I have set up Home Assistant and it is working fine.
But, when I try automations nothing goes as I want.
I want a lamp in my bedroom to light up at a certain time. But I cant manage this. Config test says it valid, but HA tells me that theres a configuration error. If I restart, HA wont start. It gives me a refused connection.
I have been playing around a lot with both these examples. But what am I doing wrong?
In automations.yaml: (Not both at once)
 - alias: "Sovrumslampa"
      - platform: time
      hours: 00
      minutes: 45
      seconds: 30
      - service: light.turn_on
        entity_id: light.bedroom_left
- alias: Sovrumslampa
    - platform: time
    after: "01:34:00"
  condition:
    - condition: time
    weekday:
      - mon
      - wed
      - fri
And in my configuration.yaml is:
Looks like both versions have spacing errors.
Try this one instead of your first option:.
    platform: time
    hours: 00
    minutes: 45
    seconds: 30
Some people even recommend putting single quotes around the numbers, e.g. ‘45’
Here’s an example with a condition that works fine in my config file:
- alias: Turn off living room light at 23:46h if nobody is home
    platform: time
    hours: 23
    minutes: 46
    seconds: 19
  condition:
    condition: state
    entity_id: group.people
    state: 'not_home'
    service: homeassistant.turn_off
    entity_id: switch.hook_b3
Thank you! Your example worked!
But if I in HA go to automations it says: We couldn’t find any editable automations.
I also wonder what spacing error is?
In order to be able to edit an automation in the HA frontend it needs to have a unique ID - for details see towards the bottom of this page: https://home-assistant.io/docs/automation/editor/
Re. the spacing error: YAML is very particular about the spaces you need to add for each indentation on each level.
I’m not very good at it, some I’m doing a lot of trial & error myself, but I’d try something like this
     platform: time
     after: "01:34:00"
   condition:
     condition: time
     weekday:
       - mon
       - wed
       - fri
Hi.I’m new in here.Please,help me how to add a single time shedule for one light.i don’t know how can I do it.i want my light turn on at morning 05:00 and turn off at late night 23:00.thanks. :slight_smile:
You will need one automation for turning it on and one for turning it off.
Look at the examples above
thanks!i see what you say but I don’t understand too much. can you write me an example?please.sorry for my english if is bad.
there are literally 2 examples above…
ahhhh.I understand now.and working.i’m new on linux too.thanks!Home Assistant is the best!
