I’m trying to figure out how to set a temperature range on my ecobee thermostats through Home Assistant. When I set a temperature in “Heat” or “Cool” mode, it works, and the thermostat changes as requested. However, when I choose “Auto” mode, which requires two temperatures (high and low), the UI looks like this:
…with only one temperature to choose. Changing this temperature causes a toast message “Service climate/set_temperature called” to appear on the screen, but nothing actually occurs on the Ecobee.
The following is my configuration for the climate view:
climate:
view: yes
entities:
- group.thermostat
- group.indoor_temperatures
thermostat:
entities:
- climate.loft
- climate.main_floor
indoor_temperatures:
name: Indoor Temperatures
entities:
- sensor.loft_temperature
- sensor.master_bedroom_temperature
- sensor.main_floor_temperature
- sensor.basement_temperature
And here’s what the view looks like:
Anyone have any idea what I’m doing wrong?
