I install homeassistant on armbian at orangepizero. Then I can’t find any notify server on homeassistant, like “notify.notify” or “notify.ios_[myname]_iphone”. I can’t find any error logs about notify server.
What should I do? It’s something I need to install?
You need to select a notification platform and configure it in configuration.yaml
The documentation contains an example of configuring a notification platform and then using it in an automation.
https://www.home-assistant.io/cookbook/notify_if__new_ha_release/
Thanks a lot.
But one thing is very strange. When I install homeassistant on Ubuntu 18.04 lst at Hyper-V, I never do anything like this document. I just login on the iOS app and configure the Home Assistant iOS on integrations page. Then the notify.ios show on the dev-service page.
I will try to configure that.
Thank you again.
That’s because when you use the iOS app it configures an iOS notification platform for you (and several other things including location tracking).
