Can't find /config folder, nor how to get Salus component to install manually - Any help VERY much appreciated!
Hi all,
I’ve been trying to figure out how to do this for several hours tonight, no luck so thought I’d try the community.
I’m trying to follow these instructions to install Salus control component, to automate my heating. Firstly, when I search HACS in the integrations section of Home Assistant, nothing comes up, so I can’t find HACS in order to use it to install the Salus control component that way.
When I try to follow the manual installation (copying the component files into config folder) I didn’t have a /config folder anywhere. I’ve tried creating /config then copying in the files, restarting Home Assistant, but Salus isn’t found in the integrations/components.
Please could someone help, I’d love to be able to control the heating via Home Assistant. But I just can’t see how to get it working.
I’m running Home Assistant on a Raspberry Pi 5, version info below:
Screenshot 2025-01-16 at 22.34.35
Install the Samba Share Add-On if you haven’t already, and then try to connect from your computer to \\homeassistant\config
The username and password are configured on the Samba Share Add-On configuration tab.
