I have a shelly US plug and it seems to be working fine. However, I cannot get it to integrate with home assistant. I am following this guide, which says:
Shelly devices use the CoIoT protocol to communicate with integration. For Shelly firmware 1.10.0 or newer, CoIoT must be enabled in the device settings. Navigate to the local IP address of your Shelly device, Internet & Security >> ADVANCED - DEVELOPER SETTINGS and check the box Enable CoIoT.
When I look at my options, though (yes I’m connected via the web interface and not the app), I don’t have the button below MQTT that everyone seems to have. Here’s what I have:
Got it. Any idea why I’m getting the “unexpected error” when I try to manually discover? It’s not auto discovering. I am connected to the same network that my device is. I am using Ethernet, but it’s still the same router and stuff and home assistant has auto detected other devices like this before.
Yes, I can see it. I also can ping it from the pi and my mac. Maybe I’m typing it in wrong in the “host” box? I’m just try typing the ip of the device right? Also I have factory reset it once.
Logger: homeassistant.components.shelly.config_flow
Source: components/shelly/config_flow.py:205
Integration: Shelly (documentation, issues)
First occurred: 7:48:23 AM (3 occurrences)
Last logged: 8:46:12 AM
Unexpected exception
File "/usr/src/homeassistant/homeassistant/components/shelly/config_flow.py", line 73, in async_step_user
info = await self._async_get_info(host)
File "/usr/src/homeassistant/homeassistant/components/shelly/config_flow.py", line 205, in _async_get_info
return await aioshelly.get_info(
File "/usr/local/lib/python3.8/site-packages/aioshelly/__init__.py", line 128, in get_info
if not supported_firmware(result["fw"]) or result["type"] in ["SHSW-44", "SHSEN-1"]:
KeyError: 'fw'
Looks like it wants firmware, but I’ve already tried updating it to no avail.
