Can't find Frigate addon (not configuration)
Trying to install Frigate on HAOS. The MQTT integration is installed and pointing at my Synology box to port 1883 with correct username and password.
I installed Eclipse Mosquito in a Synology docker container and configured and opened port on my Synology box, 1883. The container is up and running.
Downloaded Frigate and Frigate card from HACs. Restarted. When I tried to ADD the Frigate integration, it gives me several URL’s to use depending on the installation type, for instance, http://ccab4aaf-frigate:5000. But adding the integration fails.
Reading through some similar problem reports online, they mention an ADD-ON, and specifically say that this is not the integration, it’s the ADD-ON. I checked in the Add-on Store, looked through the community add-ons, but can’t find one for Frigate.
Help please!!!
What I’m saying is I don’t see those add-ons in the add-on store, even though the integration was installed through HAC.
Did you restart Home Assistance after installing the HACS Frigate app?
I did. Does the add-on install automatically through the HACS tab at the same time as the integration is installed?
I found what seems to be the addon on Github. It’s at GitHub - blakeblackshear/frigate-hass-addons: Frigate hass.io addons. So I added the repository using that URL, re-started HA, but the Frigate addon did not show up in the addon store.
Is this a fresh install? When you open the add on store do you see the blue “Add-On Store” button on the bottom right hand side?
I did another reboot and it is now there. Thank you.
That’s great. Glad you worked it out.
