Hi there, I am trying to follow the Alexa configuration guide using Nabu Casa, using latest Home Assistant version available (Core 2024.9.3). It says the first step is to activate the Home Assistant skill on the Alexa app, however when searching for it, there is no Home Assistant skill as you can see on the screenshot below. What should I do? Thanks in advance.
Figured out: the Alexa app itself should be in English for the search be able to find the skill. On the iPhone, you need to go to Settings app, find the Amazon Alexa app from the app list and then change the language there (i.e. not inside the Alexa app but rather from the iPhone settings itself). Then the search works properly and finds Home Assistant skill on the search.
I just wanted to tell you that I struggled with this issue for a week before I found your posting and you solved it for me! Big thanks!
