Not sure I understand - not familiar with docker containers.
So there’s no way for me to access mosquitto.conf when Mosquitto is installed via the Home Assistant add-on and the only way to configure Mosquitto is via the add-on configuration? SSL/TLS is part of the changes I need to make. What does
1602676447: Config loaded from /etc/mosquitto.conf.
Well there is but if you don’t understand what you are doing I’m hesitant to recommend it. Especially as the settings you want to change are available in the addon options, as I linked to above.
Haha, I’m definitely at the steep end of the learning curve. You’re right on that. The system I’m running this on is not connected to anything - kind of a sandbox environment to learn. As mentioned SSL/TLS is just one aspect that needs changing.
I’m happy to find the answer myself if you point me in the right direction.
